Introduction: How to Make a Concrete Camera
As a photography enthusiast I have cameras of all shapes and sizes, some analogue some digital, some low tech & some high but none so satisfying as the one I made myself! It doesn't take too long to whip your very own concrete camera so let's get started...
Firstly I am rather new to concrete and casting so please forgive any glaringly obvious mistakes I make along the way, I know there are definitely some things I would do differently next time around (more on that later) but if you have ideas on how any of this could be improved please share in the comments. With that said, this is how I made my own concrete pinhole camera...
Step 1: Making the Cast - Part One
The body
The body of the camera is basically a box shape with two walls inside that create separate compartments for the film to travel through. The first photo shows the dimensions of the inside part of the cast which I built out of laminated sheets of 5mm foam. I then created a box to enclose this inside part which when poured in concrete would create the walls of the camera. Finally I found a pen which had about the right diameter (12mm) to make the hole in the front - where the pinhole would be attached, and also the two holes in the top - used for advancing the film and rewinding the film once it is exposed. I glued these three pieces in place before pouring the concrete.
Step 2: Making the Cast - Part Two
The Base
The base fits snugly into the bottom of the camera to make it light tight. I made my cast being generous with the measurements then using a file I shaved the edges off the base until it fit snugly into place.
Step 3: Pouring the Concrete
Now the fun part! Mix up the concrete according the the instructions on the pack and add it to the mold, making sure to get concrete into all the little nooks and crannies. I don't have a vibrating table so to remove air bubbles I went with a combo of tapping all around the outside of the mold and also lifting it a little and allowing it to drop back onto the table. Once I was happy that all the bubbles were out I put it somewhere flat and out of the way to dry.
Step 4: De-mold & Clean Up
Once the concrete has set the walls around the mold can be carefully pulled away and you can dig out the foam from the inside. I found pliers worked pretty well to pull out chunks of foam from the inside of the camera. The front of my camera around where the pinhole goes got a little damaged when I was de-molding so I simply made it a design feature by countersinking the hole.
Step 5: Detailing & Paint Insides
Because the is no viewfinder after de-molding I smoothed over the rough top edge with sandpaper and added some guide lines to give me an idea of the field of view. To do this I marked out the half way point on the back of the camera and the two points where the walls meet the front, I then used a small file to score lines in the concrete. Finally to minimize any light bouncing around inside the camera I also painted all the inside surfaces black.
Step 6: Make the Pinhole
To create the pinhole I cut a square out of an old soda can and then placed it on to an eraser to cushion it while making the hole. Then using the thinnest needle I could find I gently pressed a hole through the tin, trying not to go all the way through but to just break the surface so the hole was as small as it could possibly be. I then went lightly over the back of the tin with some sandpaper to smooth off any rough edges the hole may have had.
Other methods for making pinholes can be found here: http://silverbased.org/pinhole-101/ that link also describes different ways to measure the diameter of the pinhole you have created so you can work out the correct exposure times later on.
Once you have created your pinhole and attempted to measure it you can go ahead and glue it inside the body of the camera.
Step 7: Making the Shutter Cover & Film Winder
There are still two vital components needed to make the camera functional, first we need something to cover up the pin hole and second something to allow us to advance the film.
To make the shutter I simply found some thin plywood and cut it out using a hacksaw into a tear drop shape. Once I had smoothed out the edges with sandpaper I drilled a hole near the top and glued some black felt onto the back to make it extra light-tight. I then scratched out a hole where I wanted the shutter to be attached to the camera and used a screw covered in glue to fix it to the front of the camera (I then covered up the screw head with a dome to make it a little prettier). This is one of those things that if I had thought ahead maybe I could have set a bolt into the concrete as I was pouring it to make attaching the shutter a little easier later on.
To make the winder I used two pieces of wooden dowel one 9mm which I cut a slit across with a hacksaw so that it would grasp the two small teeth in the top of the film canister and then I used a second larger piece of wooden dowel and attached it to the top to make it easier to grasp and twist.
Now if you put it all together you should have a functional camera, however if you are likely to go traveling around with this camera there is one more thing I would recommend to do, use two bands of rubber (I cut mine from a bicycle inner tube) and slip one over each end of the camera to hold everything together, that way it is not likely to come apart in your bag or as you move around from place to place.
Step 8: Loading Film
To load the film take an old film canister (ask for one at your local photo developing shop) and pop one of the ends off, then remove the spool from inside. Once that is done you need to tape the end of the film you want to expose onto the empty spool making sure the film canisters are both the same way up. Next you need to re-assemble the old canister, then slide both the film canisters and the film into the camera, making sure everything lines up with the winding holes at the top. Before you shut everything up take note of the ISO of the film you are using - this will help with your exposure calculations.
Step 9: Making Photos
To expose film correctly we need to figure out what aperture our pinhole is then we can use that info along with the ISO of our film to determine what the shutter speed should be. Again I used the info from the site http://silverbased.org/pinhole-101/ and this one http://mrpinhole.com/calcpinh.php to determine my aperture size, and from those I think my pinhole's f stop is around 90.
So to take photos I simply use my hand held light meter, plug in the ISO of my film and take a reading (if you don't have a light meter you can use your camera to do the same thing) then I can refer to the numbers below by Dr Evan Reece (another NZ photographer and pinhole maker, website here: http://www.ejreece.com/) to figure out an approximate exposure:
Aperture/F stop
1.2 1.4 2 2.8 4 5.6 8 11 16 22 32 45 64 90(the approximate aperture of my camera)
Shutter Speed/Exposure Time
1/1000 1/500 1/250 1/125 1/60 1/30 1/15 1/8 1/4 1/2 1sec 2sec 4sec 8sec 16sec 32sec 1min 2min ...etc
Example: You meter F.11 @ 1/60 of a second
To get the exposure simply count the steps from the aperture you metered (in this case F.11) up to that of your camera (in my case F.90) so for this example there are 6 steps from F.11 to F.90, then you simply count that same number of steps on the exposure scale so in our example we start at 1/60 of a second and count up 6 steps so we know the exposure time should be about 1 second.
Snap Away!
When you come to the end of your film simply switch the winder from one hole on top of the camera to the other and rewind the film right back to the beginning before taking the camera apart to remove the exposed reel.
Step 10: The Results
I am waiting on my first lot of test photos to be developed so I will be updating the instructable with my results very soon!
**UPDATE
My nervous wait is over - the film has been developed and it has images - yay! Unfortunately the photo store had some difficulty in scanning the images as they turned out slightly bigger than standard 35mm format so I did my best to stitch them together and match up exposures etc... however there are some places which seem to have been missed in the scanning and some frames which are sharper than others but ... oh well.
So overall the look of the photos is very lo-fi - they are in very soft focus and there have been some light leaks, and a few frames which have grit/dust on them, but overall I kinda really like the pictures especially as I wasn't expecting perfection first time around and I was relieved to find any exposures at all! They also have super rough edges and the images extend right out to the film sprockets which you can't see in these photos - I wish I had a scanner of my own so I could do some better reproductions. Anyway I had so much fun making this camera that I think I will move on to concrete camera version 2 and see if I can't fine tune it and figure out how to get it working even better. If anyone else makes their own concrete camera I would love to hear about it/see your results!!
First Prize in the
Concrete and Casting Contest
73 Comments
8 years ago on Step 8
How far do you know to wind the film to get to the next frame without over lap? and does the distance of the pinhole to the film make a difference on sharpness? or is it the size and shape of the pin hole? Yours looks so cool I tried to help my son make a pin hole camera but most of our shots where a little blurry. we used 400 iso film and hand held. the light exposure was good for his guesses based on some formula he read like your link. What film speed did you use and was your camera mounted for stillness? Thanks your shots are very cool.
I simply watched the top of the second spool turning and did one full turn between each photo, I think both the distance and size/shape of the pinhole will effect the sharpness but this is something I have to look into further because I also want sharper images! I used 100iso film and all of my shots were placed on the ground.
3 years ago
I cant afford for a premium account,
heres my e mail
julianduque125@yahoo.com
3 years ago
Hi can someone send me the pdf file for this project ?
i really need it for my photog class
6 years ago
Simply brilliant. So creative and there is something emotional about the resulting images. Bravo!
6 years ago on Introduction
Cool, and really creative! Great job!
What a solid idea!
Great!
This is amazing! Great job
8 years ago
Hi
This is a good article. Making a camera with concrete is a good idea. A very rare and cool one. I love it. It look good and creative. Also I have come acoss another one here- https://www.kickstarter.com/projects/830540667/original-pin-made-from-wood-cut-by-lasers-built-to
You should enter the analog photography competetion thingy.
Amazing
Love it! What a great idea! Looks good. Does it work? ;) http://www.sierbetononline.nl
Just wanted to say congratulations on being a finalists in the Concrete & Casting Contest! This was one of my votes so I'm so happy you are one of the finalists! LOVE this idea, so out of the box!! Good luck!
Thanks for the support poofrabbit :) I totally appreciate the vote!
I love this idea. I take star trails and this sure would be a solid and steady camera :-)
One hint: use a fine fretsaw for cutting the shutter as a hacksaw is soooo unwieldy!
Thanks - do you have any links for your star trails I would love to see them! A fretsaw look like it would be great to have for this job but for now I'm just using what I got.
Oh I didn't mean any criticism of your technique. The fine saw just makes the job a lot easier :-). Umm I'll have to put some photos up on line - if you are on Facebook I'll put some there
Best wishes
None taken :) I would seriously love to own a whole shed-full of tools but alas its just not possible now... but it is a good hint for anyone else following along - thanks!
