Introduction: How to Make a Stitched Cut
Hello! You know what this is about, no doubt, so read on and enjoy the steps and end result! I'm happy to answer any questions or take any advice.
The bruises and extra grime are optional, but help add to the over-all look. It's easy to make, has a relatively low cost, and would make a great addition to a Halloween zombie costume. (As opposed to the zombie costume you wear when you go out for lunch or to the zoo).
Materials:
-Yellow, purple, brown, and black acrylic paint
-Fake blood
-f/x flesh gel
-A bowl of hot water
-A threaded needle
-A couple cotton balls
-A sharpened pencil
Step 1: Making the Base
-Follow the directions on the flesh gel bottle by placing the bottle in hot water so that it turns to liquid.
-Pour some of the gel onto the area you wish to work on. Use your fingers to form the type of line in the picture below before the gel dries.
- Cut a line through the middle of the gel with the tip of a pencil as it is starting to thicken.
Step 2: Adding the Blood
-Dip the tip of the pencil in the fake blood, and trace the line you just scraped out.
-Mix the paints together, and add mostly black. The finished color should look like dried blood.
- Dip the cotton ball into the paint and lightly dab it on your foot, mostly around the edges of the cut.
-Of course, if you like the way the open cut looks, you can always skip adding the stitches.
Step 3: Stitching
- Thread the needle, fool!
- Poke the end of the needle through one side of the gel, and gently pull it through to the other side. If you pull the needle too quickly the gel may break. This can be covered up, but if you want a cleaner (I use that word lightly) result, than this step may take a bit of time to complete.
- Keep threading! Go back and forth between each side of the cut util you have the entire area stitched up. To end the string, cut off the excess and tie a knot.
Step 4: Results
-If you want the foot to look dirtier, just dab more of the paint from the cotton ball around the area.
In the finished picture, the cut looks somewhat shiny, but it only appears that way because of my camera's flash. The actual finished product doesn't shine in such a wonderfully glossy manner.
Thanks for reading my instructable. I'm always open to answer any questions or read any advice!
