Introduction: How to Make a Handheld Laser Pointer
There are several different ways to make a hand held laser pointer. In this case we will be creating one out of a flashlight body.
Now these lasers can be very dangerous. I built one that is only 5mw and can not burn, but for about $5-$10 more you can easily find a module that can burn (I will include links to these).
Note: At about 100mw it is possible to light things on fire.
Disclaimer: I am not in anyway responsible for anything that happens during the process of this instructable and will take no responsibility for anything that might occur.
Step 1: The Parts
You will need a flashlight body, you can take a old broken flashlight. Minimags work well.
5mw
Red - http://www.ebay.com/itm/Instapark-DRM509-L011-5-mW-650-nm-Red-Laser-Module-Line-9-mm-X-22-mm-/150828205147?pt=US_Laser_Pointers&hash=item231e0fc45b
Green - http://www.ebay.com/itm/Instapark-DGM512L-3V-5-mW-532-nm-Green-Line-Laser-Diode-Module-New-/160813153259?pt=US_Laser_Pointers&hash=item257135fbeb
10mw
Red - http://www.ebay.com/itm/New-650nm-10mW-Red-Laser-Dot-Diode-Module-with-TTL-/250943728257?pt=LH_DefaultDomain_0&hash=item3a6d696a81
Green - http://www.ebay.com/itm/532nm-10mw-Industrial-Green-Laser-DOT-module-/121175698407?pt=LH_DefaultDomain_0&hash=item1c36a26be7
Blue - http://www.ebay.com/itm/405nm-5-10mW-Violet-Blue-Laser-Dot-Module-12x35-/250943740674?pt=LH_DefaultDomain_0&hash=item3a6d699b02
50mw
Red - http://www.ebay.com/itm/50mW-650nm-Focusable-Red-Laser-DOT-Module-/260818218444?pt=LH_DefaultDomain_0&hash=item3cb9fa2dcc
Green - http://www.ebay.com/itm/INDUSTRIAL-LAB-3VDC-532nm-Green-Beam-Laser-Lazer-50mW-Diode-Module-/120920807215?pt=LH_DefaultDomain_0&hash=item1c2771172f
Blue - http://www.ebay.com/itm/Focusable-50mW-405nm-Blue-Violet-Purple-Laser-Line-Diode-Module-Sony-LD-in-/110887316066?pt=LH_DefaultDomain_0&hash=item19d1662a62
100mw
Red - http://www.ebay.com/itm/100mW-655nm-Red-Laser-Diode-Module-/281141033938?pt=LH_DefaultDomain_0&hash=item41754fbbd2
Green - http://www.ebay.com/itm/High-Quality-LAB-532nm-100mW-Green-Laser-Module-Laser-Diode-lighting-Free-Driver-/331042992973?pt=LH_DefaultDomain_0&hash=item4d13b3334d
Blue - http://www.ebay.com/itm/Focusable-100mW-405nm-Blue-Violet-Purple-Laser-Lazer-Line-Diode-Module-Sony-LD-/110887316065?pt=LH_DefaultDomain_0&hash=item19d1662a61
150mw
Red - http://www.ebay.com/itm/150mW-650nm-660nm-Red-Laser-Module-Dot-Diode-Driver-in-/170924096077?pt=US_Stage_Lighting_Parts_Accessories&hash=item27cbdeba4d
Green - http://www.ebay.com/itm/LAB-532nm-150mW-Green-Laser-Module-Laser-Diode-lighting-Free-Driver-heatsink-/231084322498?pt=LH_DefaultDomain_0&hash=item35cdb2eec2
Blue - http://www.ebay.com/itm/405nm-150mW-Violet-Blue-Focusable-Laser-Dot-Module-/200957642838?pt=LH_DefaultDomain_0&hash=item2eca024856
5mw
10mw
50mw
100mw
150mw
Step 2:
Next step will be to attach the positive end of the battery to the red wire (positive) like so
(ignore the circular metal object around the diode thats just part if my flashlight body)
Step 3:
Attach black wire (negitive) to the bronze tab inside of the flashlight body (your flashlight body might be a little bit different but this is what most flashlights look like.
Step 4:
Insert the taped battery (and any other batteries necessary). Put diode into the cap on the front of the flashlight (you make need to make adjustments on the front itself)
Step 5:
Screw the cap on and you're done! Hopefully yours work'd as well as mine did.
