Introduction: How to Make a Layered Tube Dress
Everyone would look adorable in this layered floral-pattern dress! It's such a perfect summer-spring dress so take the chance to be your own dressmaker, so join me on this tutorial and let's create together! Don't forget you can style this look by also put on leggings or with your favourite pair of high heels.
MATERIALS:
Fabric: Cotton-pattern.
Pins.
Scissors.
Measuring tape.
Chalk or a pencil.
Sewing machine.
Thread that matches the color of the fabric.
Elastic band.
Step 1: First Step
Picture #1 and Picture #2: The white fabric will be te top. So fold it and cut, you have to make sure that the fabric is wide and long enough for you measurements.
La tela blanca será el Top. Así que doblalo por la mitad y cortalo, asegúrate de que la tela sea del ancho y largo de acuerdo a tus medidas.
Picture #3 and Picture #4: See how this will turn out.
Mira como va ir quedando
Picture #5 and Picture #6: And for that first measure the bust line, mark on the fabric.
Y para lograr el top primero debes medir la línea del busto y luego marcar en la tela.
Picture #7 and Picture #8: Continue marking according to the measurements of your body
Continua marcando las medidas de acuerdo a las de tu cuerpo
Picture #9 and Picture #10: Then cut the excedent fabric, make a hem on the top
Luego corta la tela excedente, haz un dobladillo en la parte superior
Picture #11 and Picture #12 and Picture #13: Sew the hems and later each side of the top
Cose los dobladillos y luego cada lado del top
Step 2: Second Step
Picture #14: Will look like the picture
Te quedará así como lo ves en la foto.
Picture #15 and Picture #16: Then measure the length of the first layer from the waist then cut the fabric
Luego mide lo que sería la primera capa de la falda, desde la cintura y después corta la tela
Picture #17 and Picture #18: This will be the first layer.
Así te quedaría la primera capa.
Picture #19 and Picture #20: use as a guide the first layer add about 5 inches more and cut the second layer. The sew each side of the layers.
Usa como guía la primera capa agrega unos centímetros más y corta la segunda capa. Luego cose cada lado juntos las capas.
Picture #21 and Picture #22: Now you have both layers to make the skirt
Ahora ya tienes ambas capas para realizar la falda
Picture #23 and Picture #24: Sew the elastic bands to each layer
Cose la banda elástica en cada capa.
Picture #25 and Picture #26 and Picture #27 and Picture #28: As last steps sew the first layer on to the waist and then the second layer.
Como último paso debes coser la primera capa en la línea de la cintura y a continuación la segunda capa.
Step 3: Results
Good luck! :D
