Introduction: How to Make a Marshmallow Shooter
This instructable is going to show you, step-by-step, how to build a Marshmallow Shooter.  The purpose of these instructions is to show you how to build a device that will allow you to launch objects without the risk of hurting others.
Step 1: Step 1- Supplies Needed
Step 1-
Supplies Tip:  This project uses 1/2 inch PVC Pipe.  You can have your local hardware store cut PVC pipe to the required lengths.
Supplies Needed:
Mini Marshmallows
One 9 inch PVC pipe
One 7 inch PVC pipe
Two 4 inch PVC pipes
One 2 inch PVC pipe
One 3 inch PVC pipe
Two PVC elbows that are 90 degrees
Two PVC "T"s
Two PVC pipe end-caps (1/2 inch)
Supplies are shown in picture.
Step 2: Step 2
Step 2-
You will need to connect each 4 inch PVC pipe (1) to a PVC "T"  (2), as shown in the picture.
Step 3: Step 3
Connect the two "T"'s built in Step 2 to the nine inch PVC pipe (4), as shown in the picture.
Step 4: Step 4
Step 4-
Connect the 7 inch PVC pipe (5) to the T(2), as shown in the picture.
Step 5: Step 5
Step 5-
Connect the 3 inch PVC pipe (6) to the other T (2), as shown in the picture.
Step 6: Step 6
Step 6-
Connect both 90 degree elbows (7) to the 2 inch PVC pipe (8), as shown in the picture.
Step 7: Step 7
Step 7-
Connect the elbow assembly (built in step 6) to the end of the shooter, as shown in the picture.
Step 8: Step 8
Step 8-
Connect the two PVC 1/2 inch end-caps (3) to the ends of each 4 inch PVC pipe (1), as shown in the picture.
Step 9: Step 9
Step 9-
Insert mini-marshmallow, as shown in the picture.
Step 10: Step 10
Step 10-
Blow hard in the open end of the elbow device, as shown in the picture.
Step 11: Conclusion
Now that you have built a Marshmallow Shooter, it is time to have fun!  Try to be creative with different games and designs for shooters.
