Introduction: How to Make a No-Sew T-Shirt Blanket
This Instructable will show you how to make a t-shirt blanket without needing a sewing machine. T-shirt blankets are a great way to preserve memories and make use of your old t-shirts. I made my blanket because I don't know how to sew, but I didn't want to just throw away my t-shirts from high school and college. Any skill-level can make this blanket, because it largely involves tying knots. That being said, this blanket does take several hours to make. It is tedious to tie that many knots, but don't let the time requirement worry you! It is a very easy project to work on over a few days or even longer. One of the best aspects of the blanket is that is it inexpensive. The only costs of the project are the plush material for the back of the blanket, and time!
Step 1: Preparation and Cutting
1. Gather materials: t-shirts (28 panels), scissors, 12x12 in piece of cardboard, 1.5 yards of plush material, permanent marker
Note: My example blanket is 4x7 panels. if your t-shirts have designs on the front and the back, then you can get two panels out of one t-shirt. If you don't have many t-shirts you can always use the unprinted backs of the shirt, and design a checkered patters for you blanket, in order to create a blanket out of fewer t-shirts.
2. Lay the first t-shirt flat.
3. Place cardboard over logo, or other desired area.
4. Trace the cardboard with permanent marker.
5. Remove cardboard.
6. Cut t-shirt on black permanent marker line
7. Repeat steps 2-6 for rest of panels.
8. Lay our cut panels in desired pattern.
Step 2: Assembling the Rows in Your Pattern
1. Take 2 adjacent panels from you pattern. (I would suggest starting with the upper left panel, and the panel to it's right.)
2. Lay one panel on top of the other, with the designs touching on the inside. Make sure the are aligned properly.
3. Cut small strips in both shirts on the right hand side.
4. Tie the stacked strips in a knot all along the side, leaving the first and last pairs untied.
5. Take the next panel in the pattern, and do the same thing. Put it on top of the right panel.
Note: As you tie the knots, your panels will seem to shrivel up. Gently pull the edges of the knotted side to stretch it back out. You will hear a ripping sound, this is normal.
6. Repeat steps 1-5 for all of the rows.
Note: At this point, you should have 7 separate rows of 4.
Step 3: Assembling the Rows Together
1. Cut and tie the rows together
2. This is where you tie the first and last of every panel.
3. Cross the ties, so that you are tying the corners together.
This is the same process as assembling the rows, except you are cutting the tops and bottoms of the panels instead of the sides.
Note: Since you are finishing the front part of the blanket, you would be working with a lot of material. Try your best to match of the material as best as possible.
After you have tied all of the rows together, you should have all 28 panels tied together. The entire perimeter of your blanket should not be cut or tied. Your blanket is almost finished! All that is left is connecting the front and back of the blanket together.
Step 4: Tying the Front of Your Blanket to the Plush Backside
1. Lay out plush material on a flat surface, plush-side down.
2. Line up the t-shirt part on top of the backside material. (Plush should be down, t-shirt logos should be up.
3. Cut off the excess plush material at the bottom
4. Cut the t-shirt perimeter and the plush material into strips. (This part gets very messy with plush, don't worry.)
5. Tie the knots all of the way around, just like a tie blanket.
6. Throw blanket into the dryer for 10 minutes to get the plush fuzzies off.
Step 5:
Your blanket is done! It is time to enjoy your fuzzy, personal blanket. Now that you have made your no-sew blanket, you will be able to make use of all of the old t-shirts you have, and make more blanket in the future.
Trouble-Shooting:
- If you feel that the knots are hard to tie, you can cut them a bit longer or stretch them out a bit.
- If your plush is too fuzzy to deal with, you can use a lint-roller to manage the amount of fuzzies.
- Your will have to retie the ties occasionally.
26 Comments
Tip 1 year ago on Step 1
You can make as large or as small of a blanket as you want, if you don’t have many shirts you can use a square from the front and back to create a checkered look. I am currently working on one w my father’s shirts who was killed December 11th. I actually had way too many “favorite/must have” shirts so my blanket is huge, I did 15”x15” cardboard tracings to cut out and I have 4 columns x 6 rows, I know rationally your thinking why not do 5x5 right? While that would be a nice square blanket w the shirts being as large as they are 4 x 6 is equivalent to a queen size blanket, plus I am tall and thin so a more rectangular blanket seemed more fitting, But don’t worry about the size of your squares or number of shirts as long as you make all squares the same size and enough shirts to complete your chosen layout. ProTip learned the hard way…BE AURE TO CUT YOUR TABS LONGER THAN YOU THINK YOU’lLL NEED!!!! Those things get Very hard to get tied at times. I bought a hook knitting needle that has an automatic closure when you pull it through just to save some of the wear and tear to my poor fingers! Be committed is all I can say, if not it may take you a decade to get it done w a lot of shirts!
Question 2 years ago
Can you make one with only 12 t-shirts because I have only 12
2 years ago
Is the blanket loose in the middle between the layers?
7 years ago on Introduction
Question: So are the front and back only attached around the perimeter? Is it loose in the middle?
Reply 2 years ago
Did you end up figuring this out? I have the same question.
3 years ago
How can I make this blanket wider?
Question 3 years ago on Step 5
Do you cut off sleeves first?
6 years ago
how deep do you cut the strips to tie the shirts together?
6 years ago
Makes me wish I had saved more t shirts :(
6 years ago
I'm actually in the process of moving. I have been going through clothes and have a ton of tshirts from different events over the last decade. Going to put them in a suitcase and make a blanket when I move. What a fun activity to do and its a low cost stay at home project.
7 years ago
Will I be able to add t-shirts over time?
7 years ago
Hi!! this is beautiful!!! do you recommends something for the knots? to make them very tight and well done
7 years ago
Is there a fabric between the shirts and the plush fabric?!?
nope! just the two layers! My blanket is actually rather heavy, and for simplicity purposes, I just wanted to the sides.
7 years ago
Do I have to use a plush fabric or can I use an old blanket?
Hi! I see that this was almost a month ago, but in case you were still wondering, you can use anything for the back. I found the most luck with the plush because fleece backing wasn't quite wide enough for the width of my t-shirts. So I would highly recommend using a fabric that can stretch if necessary!
7 years ago
Way cool! Even I could do this.
8 years ago on Introduction
Do the knots hold up if you machine wash the blanket? Thank you! Very cool, btw!
yes they do!
awsm !!!
