Introduction: How to Make a PowerPoint Game (Dont Touch the Walls)
In this Instructable I will show you guys how to make an easy to make "Don't touch the walls" PowerPoint game.
You can make as many levels as you want but i will show you how to make one with 2 levels
Step 1: Make the Main Page
1st open a new presentation
File>New
For the main page you will need a title a background and the words: Click anywhere to start
Heres an example:
File>New
Heres an example:
Step 2: How to Add a Picture or Background Part 1 (Backgrounds)
To place a background you must right click the mouse on the slide in a free area and select
Background...
there will be a popup click the combo box (arrow)(Look at picture 1 for more info)
and then chose a color and press apply or for a picture press Fill Effects...
go in to the Texture category and press other texture(Look at picture 2 for more info)
browse for your background pic
click open then apply if you want it for all slides press Apply to All
Background...
Step 3: How to Add a Picture or Background Part 2 (Pictures)
All you need to do is press Insert>Object... (look at pic for info)
Then choose create from file and browse for your image then click ok and drag it where you want it
o ................................
>o Create from file
>o Create from file
Step 4: Make a "How to Play" Slide
1-Make a new slide
2-Then type this in the title section: (section 1 on image)
How to Play
3-Then type this in the subtitle section: (section 2 on image)
The object of the game is to get to the finish without touching the Walls
You can do so by not moving your mouse on to the walls
and by moving it on to the finish line.
How to Play
Step 5: Level 1 Preparations
This is the easiest part all you have to do is drag the subtitle section into the left upper corner and type:
"Click here to start"
Then drag the title section into the middle of the slide and type:
"LEVEL 1"
and make it big writing
here ill show you...
"LEVEL 1"
Step 6: Almost the First Lvl
Sorry before you make the lvl you will need to make a "YOU LOSE!!!" Slide
you will need to make a new slide
1st right click on the Grey part of the subtitle section and press cut
Then drag the title section into the middle of the slide and type in caps Lock:
"YOU LOSE!!!!!"
Then make a small rectangle (see pic)
right click it and click add text then type
"Click here to restart"
right click it again but this time click Hyperlink...
on the popup menu click the "Place in this document" category than select
"Slide Titles" >3.LEVEL 1 and then click OK and your done
"YOU LOSE!!!!!"
Step 7: LEVEL 1 FINALY
ta tata tum!!!!!!
YOU ARE NOW READY TO MAKE LEVEL 1 woooooooooo!!!!!
first make a new slide after slide number 3
Then delete the to sections title and subtitle
Then make a long rectangle the length of the slide and the width of about 1cm
Then Right click it and click Action Settings...
Go into the Mouse over category click the Hyperlink to: selection then open the combo box and select
Slide...
then select slide 5. YOU LOSE!!!
press ok and ok and you got your first wall
copy the wall and deform it place it however you like around the level but make shure you can make it to the finish circle
Oh ya the finish circle......... What else did i forget? JOKE
Il show you how to make it in the next step.
Slide...
Step 8: Level One Almost Complete
Time to make the finish line or circle or .................. whatever
First make a circle (see step 6 picture for the circle tool)
if i where you i would make it green
if you don't know how to make it green post a comment if i don't answer right away someone else might
right click it then click add text and type :
"FINISH"
you will need to come back to this slide because we didn't make a "YOU HAVE PASSED LVL 1" slide
"FINISH"
Step 9: Make the After Level
after the first lvl you will want to have a level saying
You have passed level 1
so make a new slide and in the title space type
" You have passed level 1"
and say congratulations in the subtitles
and at the bottom type
"Press anywhere to continue"
make a rectangle in the upper left corner and press add text and type:
Click Here to play again
then hyperlink it with level 1
now go back to level 1 and right click the finish circle and click action settings then go in the mouse over category select
Hyperlink to:
then select slide...
In the popup menu select slide
5.You have passed Level 1
and your first Level is complete
Hyperlink to:
Step 10: THE WINNERS Slide
Now before we make level 2 we need to make the winners slide
to do so we need to copy the YOU LOSE slide but instead of YOU LOSE you can say YOU WIN
or
YOU ARE A WINNER etc
but make sure its the last slide so that at the end it will end the slide show
or
Step 11: Level 2
Now this level will be like a review
First make a new slide after the you have passed level 1 slide
Drag the subtitle space into the upper left corner and type:
Click here to Start
And bring the title space in the middle and type
LEVEL 2
Then copy your level 1 slide and paste it after the slide you just made
in that slide rearrange the walls to make the level different and bring the finish line somewhere else but make sure that your mouse can make it to the finish
then make an after level (see Step 9)
but in that level make a hyperlink to the winners slide either a word or a rectangle or a circle.....
AND YOUR GAME IS DONE FINALY
I put the version i used for this tutorial that u can use
Click here to Start
LEVEL 2
