Introduction: How to Make a Shuriken Out of a CD!!!!!!
About: I'm Cool!!!!!!!!111
Do ever wish that you can own a Shuriken that can fly well like the one Naurto used? Well, you can own one right now under $10!!!!!!!!!!!!
!!!!!!!!!!!!! WARNING!!!!!!!!!!!!!!!!!!! : This is a Shuriken that can still hurt people or living thihgs (even know that the edges aren't that sharp). Please don't throw it at people. It's not my fault if you want to be a fool.
Step 1: What You Need...
You'll need the following things:
1) an old CD
2) a roll of scotch tape
3) a knife-grinder
4) a permanent marker
5) a pair of scissor
6) a ruler
7) some sand paper
8) sliver or black or gray paint
Step 2: Tapeing the CD...
Cover the CD with Scotch tape on both sides for about 3 times. Doing this will help the CD not broken up after you cut it.
Step 3: The Shape--------the Begining...
Now, take your marker and ruler and your ready for the 3rd step. Use the ruler and draw a cross on the taped CD (as shown in the picture). Make sure the corners are 90 degrees. Next, turn the CD so the cross look like a X and draw a dot in the middle with the distance of 1.5 cm from the center (or in the middle of a 90 degree angle,look at all the pictures).
Step 4: The Shape--------Part 2....
Now, draw a line from the tip of a line of the cross (or X) and pass it through the dot, not passing the other ling of the cross. Each dot will be passed by only two lines.Repeat for the rest and you should be finish with the shape. Look at the pictures for a better understanding.
Step 5: Cutting the CD...
Follow the lines, cut the un-needed parts out with a big scissor ( like i did in the picture). Be careful, the CD might break during the cutting, and if it did, just put some more tape on it.
Step 6: Sharpening the Edges...
Take your knife-grinder and start grinding the shuriken on the edges so it look like it's sharp. Do it to every edge and also the back.
Step 7: The Painting...
For the last step, put the shuriken on a piece of paper and paint one side at a time. After one side had dry, paint the other side. After 1 day, you can use it.
Step 8: Finish!!!!!!!!!!!!!!!
Finish!!!!!!!!!!!!!!! Now go out and test it!!!!!!!!! Be safe and have fun!!!!!!!!!!!!!!!!!!!!!!!!!!!
