Introduction: How to Make a VHS Video Toaster
The project was simple: convert a VHS video machine to make toast, and eject it through the cassette slot.
If I thought anyone would attempt this (and they shouldn't) I'd offer the following warnings:
Ensure the metal parts are earthed (I did)
Do not place it on heat-sensitive surfaces.
Do not place heat-sensitive materials on top of it.
Take care not to touch any hot surfaces.
Do not leave the machine unattended.
Step 1: Parts List
VHS video recorder/player - I used a Daewoo ST862P
Toaster - I used a Swan Elegance single slot "thick & thin"
Metal sheet - From steel drinks cans
Epoxy glue - (cheap, two part)
Tools:
Dremel-a-like tool
Pliers
A sharp knife
Sharp scissors
A screwdriver
Step 2: Toaster Dismemberment - Phase 1
This toaster was not designed to come apart, but the plastic case must come off. In this step I stripped off what I didn't want and wasn't going to use
On the underside are Torx screws for which I did not have bits. The two prominent screws were removed with pliers, the others had the brown plastic hacked away from them until I could finish the job with pliers.
The two control knobs are friction-fits on this machine and only required a good pull to get them off
Whilst doing this I observed that the outer shell is rather hard and must have good heat resistance. To some extent the toaster self-cools by natural convection, the last photograph shows the the comparison between inner and outer.
I wasn't going to be able to rely on this type of cooling or plastic in the video.
Step 3: Toaster Dismemberment - Phase 2
Once you're past the outer case on this toaster everything gets much easier. Most of the construction is held together by metal tabs, bent or twisted to secure. This is the stuff I need.
The electrical connections to the heater elements were push fits, the pulled off with pliers. Take care with this type of heater element, the mica support is fragile.
I needed to take the whole thing apart because the toaster has a central slot, the video has an off-centre slot. While it wasn't possible to bring the toaster fully up to the level of the VHS slot, it could be moved a bit.
Step 4: Video Dismemberment
The video was much easier to strip than the toaster, a few screws and I was done.
The front panel was a clip-fit, easy-on, easy-off.
Step 5: Toaster Adaption
It was apparent from the start that this would be a tight fit, so some of the video's black side-wall had to go (Dremel-a-like tool).
Having tested the toaster without it's case, I didn't think it a good idea to leave a sheet of black polystyrene under it, and some bits of this would have to be removed anyway (Dremel-a-like).
There's a thin steel sheet underneath the plastic floor.
The toaster has two chrome racks which hinge at the bottom, and are pushed central at the top so that they grip the bread in a central position - at varying thicknesses.
I fixed the top rack at it's thickest setting, and moved the bottom rack to "very thin". The overall effect is to move the toast off-centre and more towards the top in the finished machine.
Step 6: Assembly of the VHS Toaster
The main push-to-activate lever was bent around a piece of stiff plastic tube. In the horizontal position this now pushes forwards, rather than down as in the original toaster.
I hacked the play button from the video, and attached it to the tube with a screw, before adding epoxy glue to finish off.
The toast brownness control was simply set at a reasonable level and left there, I'd spent too much of the weekend on this already to be finding an adaption for that.
An "exit ramp" was formed from another piece of steel sheet. This guides the toast from the chrome rack, out through the VHS slot. Another spin with the Dremel-a-like cut slots in the front panel to secure the ramp at that end. The other end of the ramp was tucked into the toaster heat-shield / reflector (see images).
After that, back on with the case and let's start toasting!
Step 7: The Finished Product!
Three shots of the finished machine.
It does toast, see the video.
Yes it gets hot, yes I want to fit at least one fan before I use it again
L
Step 8: "VHS" Toast
I'd originally intended for the toaster to leave "VHS" on the toast. However, the top rack was too far away to be effective, and I knew that while it would work on the bottom rack the toast would stick to the VHS mask.
I laid the mask on the bread and toasted it in the toaster, horizontally.
Yes, I switched slices in the video, for artistic purposes.
L
179 Comments
8 years ago on Introduction
Weird but awesome. Nice idea!
10 years ago on Introduction
I do believe I recall reading an idea of yours on this weeks ago... In the forum, mayhap? I'm glad to hear you executed it, this really is a wonderfully creative idea.
Not any more, I had a hair-cut last year and I shaved last week...
L
WOW! Such an imagination!! What an awesome idea!
This is an awesome job. I always like wacky interesting ideas, but it's really something else to actually do it and make the thing.
I think I would probably break all the components, burn down my house and/or electrocute myself if It tried this one, but respect to I love it.
and if you turn the toast upside-down, it says SHA!
No it still says VHS.
The V & S would be upside-down though.
L
Beta makes better toast
It's not a real video toaster unless Wil Wheaton works for you.
11 years ago on Introduction
EPIC!
13 years ago on Introduction
I think that the opposite of this would be pretty funny, you put the insides of the vhs player inside the empty toaster so you have a vhs playing toaster.
Or you could put a cd optical drive inside the toaster and put a blank cd in it and burn it, people will think you're literally burning it but you really aren't.
Reply 13 years ago on Introduction
I like the second suggestion - if you could have the disk pop-up like toast!
L
Reply 12 years ago on Introduction
Really it would be easy, just get a slot loading optical drive, probably a laptop one, and an external enclosure for said drive and mount it in. Maybe wire the eject button to the lever...
Reply 11 years ago on Introduction
Great idea!
that would be a great addition!
you'd have to prevent the disc from falling out from the side though.
anyway, the humor is what matters right? :-)
Why didn't someone think of this sooner! Then, instead of filling up rubbish dumps with old VHS tapes, we could just butter them and eat them. You are an ECO genius.
I don't suppose you know how to turn an old CRT TV into a microwave oven while you're at it, do you? My microwave has blown up, but I've got an old TV in the garage no-one wants.
this whole project just gave me an amazing idea... what if you could make a printer that could print on food with food coloring? imagine, tortillas with funny pictures on them... definitely will have to think more on that one...
thay print on fondont
It already exists!!!
Not hard to do I think.
L
