Introduction: How to Make a Cheap and Easy Vaporizor
If you smoke, you know how bad it is for your health. Vaporizing is the cleanest, purest way to get the effects of what you are smoking, without the harmful toxins.
This vaporizer was built from household objects and requires very little tools.
Step 1: Materials....
Materials needed are:
Heat gun w/variable temps
Martini shaker w/ strainer and lid
One foot 3/8 clear tubing
Threaded hose fitting
Open/close valve
Some smoke
Tools needed:
Drill
Drill bits
Open/close valve
Some smoke
Tools needed:
Drill
Drill bits
Step 2: Drill....
Drill a hole in the bottom of the shaker. Drill it big enough so that you can thread your hose fitting for an air tight seal. Then drill small holes in the top of the strainer cap.
Step 3: Attach...
Attach the open / close valve about three inches from the bottom of the shaker. Check all connections for air leaks.
Step 4: Put....
Put it all back together. I use an extra screen to prevent the shake from entering the chamber.
Step 5: Stick.....
Stick the whole thing in the freezer to chill for awhile.
When your ready to smoke, load the top with your favorite.
Turn your heat gun on low ....and
VAPORIZE!!!
Be sure to open the valve.
VAPORIZE!!!
