Introduction: How to Make a Cheap Home Made Par Can
Ever wanted to have disco lights in your own home but found they were too expensive for what you wanted ??
Well with this project you can build a par 46 can for about $10-15
Step 1: Breif Introduction
Par cans, are the leading light in night clubs, dj's, and stage productions but they can also be used around the home to lighten up things.
The size of par cans are measured in Par's. 8 "Par's" is 1 inch.
Eg. 64 Par is 64/8=8 inches
My Par can is 46 Par (do the math) and you can make any size using tins from anywhere
Step 2: Materials
To make a Par Can you need:
1 Large tin (this will be your par can. please read ahead before selecting your tin size!!)
(I used a 4L punch juice tin for mine)
1 Power cable with male end (end that plugs into the wall) and other end bare wire
1 Standard light fitting (from your country)
1 100W bulb
spare 240v single wire
Pvc pipe of 2cm diameter
bolts, screws, hot glue, electrical tape
FOR THE COOLING UNIT (recommended)
1 tin slightly smaller in diameter than your parcan
1 12V fan
240VAC-12VDC converter with cable
hot glue, screws
Step 3: Building the Parcan Part 1
1st picture/step: mark on the base of the tin where the light socket will sit. Try and get it close to center also mark out the holes where you need to drill to bolt the light socket down
2nd picture/step: Drill a hole where were you just marked so that the bolt fits neatly through
3rd picture/step: Drill a hole directly in the center big enough for the power cord to fit through
4th picture/step: Drill fiarly big holes all around the tin base BUT THEY MUST BE outside the light socket markings
5th picture/step: flip the can and pull the cord through the center hole so that is on the inside of the can. Then Strip the 3 wires and screw them into the appropriate places on the light socket
6th picture/step: Add the spare wire in with the earth wire. For this diagram I used a red wire.
7th picture/step: Pull the light bulb socket back through to the bottom of the tin (now it should be on the inside) and bolt it down using the holes that you drilled (Keep the red wire lose so that it is not stuck under the light socket and you can get to the end of it
8th picture/step: drill a hole close to the open end of the can that woll allow you to put a SMALL bolt through(Make sure the red wire can go through that hole)
9th picture/step: put the bare wires of the red wire around the head of the bolt so then from the inside put the bolt through the hole and tighten it with a nut make sure its really tight.
AT THIS POINT YOUR PARCAN IS FINISHED BUT READ ON FOR THE STAND AND COOLING UNIT
11 Comments
13 years ago on Introduction
You've only got 1 tiny photo of this, can you add any more?
What type of 100W bulb did you use?
L
Reply 13 years ago on Introduction
just a standard 240v bayonett head bulb, i'll post some more pics, has that answered the question
missing the cooling fan part of the instructions
I wondered if you'd used one of those spotlight bulbs that are partially reflective, but thanks.
L
I only used a standard bulb because thats the socket i had, if you can find a socket for those floods you can use them but make sure you have appropriate cooling methods in place i.e. a fan
Standard-fitting "flood light" was my thinking. The cooling is a good feature of this.
L
9 years ago on Step 3
weres the cooling fan instructions for the light?
12 years ago on Introduction
i could use leds and lemon juice batteries to make a small one
PAR is short for Parabolic Aluminized Reflector, a descriptive term regarding the shape of the lamp and its internal reflector
Most lamps are measured in 1/8's of an inch. often this is preceded by a letter or series of letters that tell you the shape and size.
for example that old four foot long florescent lamp over your workbench likely has a "T12" noted on it, that "T" stands for "tubular'" and it is 1.5" diameter.
the newer shop lights may be T8 or 1 inch
The length of the tube is in normal inches.
That 100watt lamp in this project appears to be a typical "A" or pear shape
This looks like something that'd be perfect for low budget feature film lighting.
ha, i like it, your own little par can 46 made out of actual cans, my lighting teacher would like this
