How to Make a Claymation+props
Intro: How to Make a Claymation+props
In this instructable I will show you how to make a basic claymation with props.
STEP 1:
To make this instructable you need
- Exacto Knife
- Thin Foam Boards
- Colour Printer
- Paper
- Computer
- Modeling Clay
- small Wire
- Camera
- Ruler (or squared ruler)
- measuring tape
STEP 2:
BUILDING PROPS
- measure out how large you would like your building walls to be.
- use a ruler and trace out your walls using a marker.
- Cut out your wall peices.
STEP 3:
- Access the internet and find a building wall
- open a photo editing software and copy+paste the image into it
- Change the image size to the measurements of your prop walls
- Go into file on the top left of your program and select print.
- Make sure your colour printer is hooked up then proceed to print the image, I suggest using a 8 and a half by 14 inch paper.
STEP 4:
- Use scissors and cut out any unwanted white space in the printed paper(s).
- Use a stick of glue and paste the printed paper to your measured and cut wall.
- To assemble the walls you need to use tape and cut off two 4" peices.
- Tape the corners of the walls together to complete the building.
STEP 5:
Clay Characters
- Use the modeling clay and mold the clay into any character you would like to put in your video (I use a plain generic character).
- You can mold other things Like weapons or bags for example.
STEP 6:
Making the Scene
- Now that you have made your building and your characters, it is now time to make your scene.
- If you dont want a plain real life background like your desk then I suggest you use a green screne to add backgrounds to your claymation.
- So set up your scene either on a green screen or not
STEP 7:
- If your using a green screen then you must use a video editing program that can add a background to your video.
- Use can use a camera to catch your scene or you can use a picture capture software that allows you to use a web camera to take multiple pictures.
- I used stop motion pro 7 for my animations.
- To make your character animate you must take a picture of your scene with your character in it and move your character bit by bit, taking pictures with every slight adjustment you make.
STEP 8:
If you have a photo editing software or if your software has a photo editing option then you can use wires to make your character jump or fly. When you are happy with how your jump or flying scene turned out then use a rig removal tool in your software to remove the wire so that it looks like it was never there.
STEP 9:
My Animation Video
This is an example of an animation
