Introduction: How to Make a Easy Smoke Bomb
Say do you like bombs? Why of course you do i mean who doesn't! Anyway have a go at this smoke bomb and you'll be a pro bomber in no time! This bomb is very simple and easy to get the supplies. So go ahead try it out!
Step 1: Supplies
First, you will need your supplies. For this instructable you will need 5 things. You will need a can of any tipe (i used a dr, pepper can), a sheet or two of paper any kind, a knife, matches or a lighter, and a flammable substance(i used axe body spray). And sorry if i did anything wrong (no not the smoke bomb i know that is right) because this is my first instructable.
Step 2: Cut a Hole
Cut a nickel size hole in the bottom of the can and position it so that you can see straight in through the bottom hole and out of the top hole.
Step 3: Shred the Paper
Next you need to take the paper and tear it up into small shreds.
Step 4: Stuff in the Paper
Now your going to take a handful of the paper and stuff it inside the can through the top hole.
Step 5: Spray the Paper
Take the flammable substance that you are using and spray it really good all inside of the can. Make sure that you have the paper inside coated pretty good with the spray.
Step 6: Light 'er Up!
Now you can take the matches or lighter it does not matter but light the paper on fire from the bottom hole and make sure that the fire is well lit so that it does not go out. Now you should start to see smoke coming out from the top hole. So smoke and enjoy! And please comment or whatever because like i said i'm new to this stuff so do a guy a favor eh!
