Introduction: How to Make a Fishing Jig
Disclaimer: Warning the lead is very hot (621F) and the breathing lead fumes can be hazardous to your health. You should always be in a well-ventilated area and also wear safety goggles and gloves. Please take all necessary steps to ensure that you are properly protected. Make sure to wear eye protection and keep all liquids away from molten metal. Adult supervision is essential if children or youth are involved. Safety is always important and it should be noted that this instructable is not intended as a safety guide but rather an overview of the process. Adult supervision is essential if children or youth are involved.
Step 1:
Step 1: Plug in the Melting Pot to melt the lead. Caution: The lead is toxic and melting lead can expose you and others to dangerous fumes. These fumes are known to cause cancer and birth defects. Always make sure you are in a highly ventilated area. The fumes from the lead are where all the damage is. Make sure you are using a flat surface that will not be damaged if lead gets on it or a surface that can easily be wiped off. Once lead is melted you can skim off any impurities with a spoon.
Step 2:
Step 2: Place desired hook in mold. I have several different molds so it just depends on what kind of jig you are making.
Step 3:
Step 3: Place mold under the melting pot and lift handle to dispense the lead to fill the mold. You don't want it to full but you are going to have some lead on the top of the mold after filling.
Step 4:
Step 4: Open mold and remove jig. Make sure that you use pliers to remove the jig head. It will be extremely hot. Let cool.
Step 5: How to Make a Fishing Jig
Step 5: Once cool you can remove excess lead with pliers.
Step 6:
Step 6: Heat Jig with heat gun. Make sure you don't remelt the jig head, you just want to heat it up so the powder paint sticks to the jig head.
Step 7:
Step 7: Dip in powder paint and shake off excess. The jigs usually dry pretty fast and the powder paint is not messy.
Step 8:
Step 8: Put on weed guard and select the desired skirt. Your almost finished with the best fishing jig ever!
Step 9:
Step 9: Final Product. Put on skirt and there you have an Awesome Fishing Jig! FISH ON!!!!!
Crafting Speed Challenge
Indestructibles Contest
3 Comments
8 years ago on Introduction
lead is extremly dangerous but i did do it with help with my dad
10 years ago
Where does one get the skirt for this?
www.jannsnetcraft.com
