Introduction: How to Make a FREE PS2 Stand
Once I got my PS2, I didn't want it to overheat. So, I wanted a stand. The problem was, I didn't want to spend money on a retail stand. Instead, I made my own. It turned out to be a horizontal PS2 stand, but it works perfectly!
Step 1: Get Two CD Holders
Before you start, you will need two CD holders (mine are thin, but fat ones will work). The fat CD holders will work better, but will make your PS2 look fat.
Step 2: Slip the CD Holders Under the PS2
Secondly, slip one CD holder under the PS2. Then, you slip the other one under it.
There should be enough room for a lot of air to go between the two CD holders. Otherwise your PS2 will probably get overheated.
Step 3: Extras
If you have a silver PS2, you can make a CD cover for the disk holder or just use a different colored holder. You could also just use the original black color (might not look as nice).
If you want to use a different color, like maybe white, for your stand, then just make a CD cover that is white or the color you want to use. You could also wrap colored or white paper around it.
If you can think of other ideas, then, if it works, you may use them.
This trick should work. If it doesn't work, you can contact me at http://crazyguy64.webs.com/ (or you can just message me a different way if possible).
