Introduction: How to Make a Mini Rocket
What you need.
2 matches
tinfoil about 6cm long and 4 wide
paper clip
Step 1: Step 1
What you do is take a piece of tinfoil and the 2 matches.
cut off the match heads but don't throw anything out put the 2 match HEADS in the middle of the tin foil and put one match stick in one side to create a hole for the gas to cone out than roll it up really tight but keep the match stick in there,
so in one end we have the match stick and one end is rolled up so the gas can't escape out the top.
Step 2: Step 2
Get the paperclip and make a stand for it however you want than put the mini rocket on the stand but first take the match stick out of the end so there is a hole coming out the end than put your rocket on the stand whith the end of the paperclip in the hole but watch out you don't squash the hole in the prosess.
Step 3: Be Carefull !!!
If your rocket doesn't go off it's because you didn't listen or because you put in 1 match instead of 2 or you put more than 2 in.
It isn't my fault if you get hurt and think about it before you make the rocket and have your parents permission
