How to Make a Really Cool Gas Powered Motor Bike
Intro: How to Make a Really Cool Gas Powered Motor Bike
make a cool bike that make a great speed of 20 to 30 mph ( depends on CC of
engine too )
Materials:
fishing line
a box of straws
a small box
a Bike with hand brakes
a bike rack that connects to the seat
a couple different sized chains
and a 49cc to 100cc engine
tips:
if you get a chain saw engine it will have lots more torque and power,
if the engine has a clutch it works better
engine too )
Materials:
fishing line
a box of straws
a small box
tips:
STEP 1: The Engine
I mount the engine ( green ) on the rack of the bike
with the gas ( red ) tank strapped on to the box ( yellow ) strapped to the rack ( orange )
STEP 2: The Throttle
The throttle on the engine should be near the carburetor and it's a little lever that I tie fishing line to
I tape straws ( blue ) on the side of the bike running fishing line through them,
the hand brake for the front tire disconnect it from the brake the tie the remaining end of fishing line to the brake handle
STEP 3: The Chains
Take a couple chains until you find one that fits tightly and snugly
In the picture it is running from the engine to the back gear
STEP 4: Starting Up
Pull the handle with the cable to start the engine then test your throttle by puling on it like a brake
then test ride
then test ride
28 Comments
StressedC 5 years ago
Wolf321 8 years ago
It would be very helpful if you could add pictures or videos of your build so that we can see how yours turned out and build ours to match that.
DOMIN8ER 11 years ago
Wolf321 8 years ago
Unless you have a transmission, it sounds like you could have a bad gear ratio. I recommend trying to add a clutch and shift lever, but that might be hard...
Kcip 11 years ago
Hope this helps.
Mark
bmueller3 11 years ago
philupk 9 years ago
also, where do i get a chain sprocket that fit my chain and engine?
philupk 9 years ago
how do i attach the motor to the bike rack? i have a chainsaw powerhead.
LiquidLightning 12 years ago
rimar2000 12 years ago
Koolaide58 12 years ago
I have buils one so it took several trys to get it right .but it will take off with my 230 lb but on it and not have to peddal at all and run 25 mph easy if you want to go that fast ?
abell18 12 years ago
heathbar64 12 years ago
rimar2000 13 years ago
TSC 12 years ago
Materials:
fishing line
a box of straws
a small box
TSC 12 years ago
