Introduction: How to Make a Shoe
DO NOT USE A SHOE WITH A SHINNY SURFACE! BECAUSE YOU MAY END UP SCORING YOUR SHOES!
Step 1: Wrap the shoe up until it is covered
Don't close over the hole.. because you will need to get the shoe out of the mould
The more tape you use the stronger the show will be!
Step 2: Once you are happy with the amount of layers...
Step 3: carefully prise the layer rim from the actual shoe so that you can cut
Step 4: Cut so each side and front of the shoe
If needed you can always cut at the back of the shoe; but do not cut away down to the heel!!!
Step 5: When you are happy with the cuts you can now gently prise the mould off the actual shoe
Step 6: Once you have prise the mould off completely you will end op with a glass like shoe!
Step 7: Straighten out any possible dents that you might get while taking the mould off!
Step 8: Once you have done that tape up the areas that you have cut!
