Introduction: How to Make a Simple Fishing Lure With Office Materials in Under 5 Minutes!!!
bored? fish? i've got a solution, make some fishing lures!
what you need:
-paper clip
-tape (i used electrical tape)
-sissors (something to cut the tape)
-pen with a rubber grip
-fishing hook (one shown works best)
*** if you don't have a hook, check dicks sporting goods, walmart, meijer, etc. you can get several for cheap!
*** haven't used it yet, but i'll post an update if i catch anything...
what you need:
-paper clip
Step 1: Taking Off the Gripp
unscrew the tip of the pen, then twist/ turn the grip off. the grip can be difficult to take off depending on what pen you use. *** you still can use the pen by placing the tip back on, it just won't have a grip
Step 2: Attaching the Hook/ Rubber
bend the paper clip so it's open as shown, take and slip the hook through and to the bottom of the clip. close the paper clip the best you can, then tape it a few times around, this will make it stronger, and help the rubber from slipping. slide the rubber on, allow enough room at the top of the clip to tie.
Step 3: FINISHED!
this is just a general idea of how it should look. can't wait to try it, don't care if it works or not, it was FREE!!!
good luck fishing!!!
