How to Make a Small Bamboo Pipe.
Introduction: How to Make a Small Bamboo Pipe.
I was bored, so i decided to make a tobacco pipe, out of some small bamboo.
This was how it's made:
Step 1: Get Yourself Bamboo
i was walking down a road on my street, when i saw a small thicket of bamboo, so i grabbed a piece about 3/4 inch in diameter and one about 1/8 inch in diameter
the longer a piece you get, the more pipes you can make
Step 2: Cuttin It Down
with the thicker bamboo, from a notch cut about (just my idea) 1 inch from the notch, straight across
and with the smaller, cut about a 4 inch piece with holes on both ends
Step 3: Making It
with the bowl end, scrape out the inside flesh and let dry, and with the pipe, let dry
use a drill to drill a hole slightly smaller than the end of the pipe, and slide it in
glue if you want, if not you can take it apart for easier carrying
enjoy
Step 4: More
DON'T GET CAUGHT IF YOU USE IT TO SMOKE WEED
i highly do not recommend it
Be the First to Share
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    • Big and Small Contest
    19 Comments
    Lt. Duct Tape
    Lt. Duct Tape
    12 years ago on Introduction
    I'd just like to make a point here: Bamboo is nature's fiberglass. As such, I strongly suggest you coat the inside of this pipe THOROUGHLY with wax. An experienced pipe-maker taught me this trick when I was younger, and from what he told me, it saved me from microscopic slivers and a nasty infection. No, this does not mean that you can smoke out of a fiberglass pipe as long as it's covered in wax ;)
    NayChank
    NayChank
    Reply 6 years ago
    Hello there, I realize this is a very old post but if you are still around, may I ask as to what kind of wax should be used to coat the inside of the bamboo pipe? And how do you do so? Thank you!
    markus2102
    markus2102
    13 years ago on Step 4
    i really wish i could get my hands on some bamboo where i live haha nice ible
    ParacordJedi
    ParacordJedi
    Reply 11 years ago on Step 4
    You say you need to get your hands on some bamboo like you already have the weed hahaha
    mdog93
    mdog93
    14 years ago on Step 3
    how do you get the pipe/ tube end to be hollow all the way through mdog
    savebarcelona091
    savebarcelona091
    Reply 13 years ago on Step 3
    bamboo is hollow except for the water blocks so you can just use the pieces between those
    dbell
    dbell
    Hard to find 4"+ long pieces that slim, without nodes.
    I think I may have to fashion a drill from a piece of coat hanger wire...
    Cut a length of straight steel wire.
    Cut one end to a fairly well centered point.
    Hammer the point to flatten and thin it a bit.
    Grind edges on a stone or concrete surface.
    Pass down the length of the pipe stem and twirl with fingers to drill through intermediate node blocks.
    HAL 9000
    HAL 9000
    Reply 12 years ago on Introduction
    I've used coat hangers before, but didn't have to flatten the end. Just use some wire cutters and they will leave an edge suitable for drilling through wood. I used to do this when drilling through floors to install forced air heating systems. a regular drill bit would get all tangled up in carpet fibers, but the coat hanger would go straight through.
    mdog93
    mdog93
    Reply 12 years ago on Step 3
    yeah that might work
    todbro
    todbro
    13 years ago on Introduction
    Dont get caught if you smoke weed??? Shouldent it be don't smoke weed??
    JakeTobak
    JakeTobak
    14 years ago on Introduction
    Pretty kewl, how does it hold up to smoking? Is it a one time use thing or can it be used on a more permanent basis? Also, does it have any weird taste when you smoke it compared to a pipe you might buy from a smoke shop? If your camera has a macro mode, you might be able to get clearer pictures by the way.
    cdawg14
    cdawg14
    Reply 13 years ago on Introduction
    bamboo holds up very well to continued use. It does create a bit of an odd taste at first, but this eventually goes away as you use the pipe more.
    pugsleyboy
    pugsleyboy
    14 years ago on Step 4
    that's pretty cool i've always wanted a pipe but have no money to buy one did you use green or dead wood?
    Gypsyman
    Gypsyman
    Reply 14 years ago on Introduction
    since it says "let it dry" i can only assume he used green wood.
    pugsleyboy
    pugsleyboy
    it looks quite green though bamboo does tend to keep it's colour well i suppose
    Chicken2209
    Chicken2209
    these pictures are really blurry I recommend using a solid surface like the table the pipe is on to get a steady picture Right now, I can't tell if thats a pipe or a gavel
    HotPinkBulb
    HotPinkBulb
    Thats some nice work! The pictures are a little blurry, it might be worth having another go at taking a good final picture.
    discontinuuity
    Pretty cool idea. Just one suggestion: use the macro setting on your camera, or draw some diagrams. Clear pictures make an instructable much better!
