Introduction: How to Make a Software Clock
To explore the Arduino world I have, when buying the base Board, also purchased a multi-shield for an amount of just over € 7.00.
On this shield there are a number of options including a 4 digit display and 3 buttons, witch I first used to make a software clock.
Apart from the digits and the buttons I later have used the LEDs, the buzzerd and the potentiometer:
The LEDs to give a ¼ minute signal.
The buzzerd to generate an hourly chime.
The potentiometer to the evil time:
-turning clockwise is faster
-turning against the clock is slower
Step 1: The Program:
By perusing a concise manual and looking at examples (here and there) I came to the following program:
(sorry i don't know how how to get this in a nice window)
/* Learning how to programming Arduino */
/* by Rob van Staalduinen - Netherlands */
byte num[]={192,249,164,176,153,146,130,248,128,144,64,121,36,48,25,18,2,120,0,16};
// array with numbers 0-9 and 0.-9. (for hour digit [1])
byte time[]={0,0,0,0}; // array for putting the time in
byte push; // button-push delay counter
void setup ()
{ for (byte a=3;a<=13;a++) // sets datapins 4 to 13 to OUTPUT
{ pinMode(a,OUTPUT);} // 3=buzzer 4=latch 7=clk 8=data 10-13=leds
digitalWrite(3,HIGH);} // stops the buzzerd from beeping
void loop()
{ long speed = 37500+(1024-analogRead(0))*2; // time counter; changes time-speed for
// differend boards use potmeter on shield
for (byte c=10;c<=13;c++) // leds loop
{ digitalWrite(c,HIGH);} // sets seconds-led [c] to off
For (long a=0;a<=speed;a++) // delay timer
{ if (analogRead(1)==LOW) // reads button1
{ time[1]=time[1]+(!push);push=60;} // adds 1 to hours
If (analogRead(2)==LOW) // reads button2
{ time[2]=time[2]+(!push);push=60;} // adds 10 to minutes
If (analogRead(3)==LOW) // reads button3
{ time[3]=time[3]+(!push);push=60;} // adds 1 to minutes
push=push-(push>0); // down-counter for button-push
if (time[3]>9) {time[3]=0;time[2]=time[2]+1;} // sets minutes + 10 if over 9 and go to 0
if (time[2]>5) {time[2]=0;time[1]=time[1]+1;} // sets hours +1 if over 5 and go to 0
if (time[1]>9) {time[1]=0;time[0]=time[0]+1;} // sets hours + 10 if over 9 and go to 0
if ((time[0]>1)&&(time[1]>3)) {time[1]=0;time[0]=0; // sets hours to 0 if higher than 23
digitalWrite(3,LOW); delay(30);digitalWrite(3,HIGH);} // beeps every hour
for (char b=0;b<=3;b++) // loop for writing 4 digits
{ digitalWrite(4,LOW); // disable outputs
shiftOut(8,7, MSBFIRST,(num[time[b]+10*(b==1)])); // writes number-data
shiftOut(8,7, MSBFIRST,(241+(b==1)+3*(b==2)+7*(b==3))); // writes digit-data
digitalWrite(4,HIGH);} // send data to outputs
digitalWrite(a/(speed/4)+10,LOW);} // sets 15 seconds led
time[3]=time[3]+1;} // adds 1 minute to time
Step 2: The Shield
I can recommend the shield for beginners because it has except the above mentioned functions also various other connectivity options such as blue-tooth, voice recognition, infrared, variable resistor and various other connections for just about everything available for additional options.
The shield I found you can see with the following link:
http://www.banggood.com/4-Digital-Multi-function-S...
There are also hundreds of other issues to find, a couple of them I already ordered.
Hopefully the program gives some look on the possibilities that Arduino programming offers and have I helped some people with this search a little further with their hobby.
Writing a program in as few bytes as possible I actually find even more fun than soldering.
Best regards,
Rob van Staalduinen
Step 3: Extra Information
Multi function shield connection pins (for programming):
Analog:
0 – Pot
1 – Button 1 - jumper2 to -
2 – Button 2 - jumper2 to -
3 – Button 3 - jumper2 to -
4 – LM35 – jumper1 to +
5 – Shield connector 4
Digital:
00 – Bluethooth
01 – Bluethooth
02 – IR
03 – Buzzer
04 – Display - load / latch
05 – Shield connector 1
06 – Shield connector 2
07 – Display - clk
08 – Display - datain
09 – Shield connector 3
10 – Led 4
11 – Led 3
12 – Led 2
13 – Led 1
