How to Make a Spanner(wrench) Out of Pvc.
Intro: How to Make a Spanner(wrench) Out of Pvc.
I've seen some pretty amazing pvc projects here and I thought I must do a nice and simple pvc project as my first instructable. It can be done in 5 minutes and costs about nothing.
STEP 1: Required Stuff.
Materials needed:
Short piece of pvc pipe.
A source of heat (I used a tea candle).
A metal rod.
Bolts or brass fitting.
Pliers to hold the bolts.
Note: I'm having trouble adding notes to the image.So please bear with me. My problem has been solved thanks to Tool Using Animal.
A metal rod.
STEP 2: Forming Your Pvc
Just heat your bolt until it is extremely hot. Now take the pvc pipe and push it over the hot bolt.It will slowly start going on.Now cool and repeat on other side of pvc(only if you want to have a twin sized spanner).
STEP 3: Drill and Add Handle
Drill a hole through the middle of your pvc and insert your metal rod. Your done. Now go and use your new pvc spanner/wrench.
24 Comments
cgosh 10 years ago
Technically, although this is a terrific idea, it's not a spanner. Check images.google.com to see some. They "span" a large gap.
BTW, if this tool isn't tough enough to suit you but you still don't want to spring for a metal wrench, try wrapping wire or strong cord around the outside, and/or coat it with epoxy (try JB Weld brand, cures very hard).
Hand-made tools. Gotta love 'em. Thanks for the idea.
Oorspronklikheid 10 years ago
PetervG 17 years ago
Apples 17 years ago
servant74 16 years ago
Gorfram 15 years ago
Phil B 12 years ago
claudg1950 10 years ago
Legolutionary 16 years ago
holeman666 16 years ago
JakeTobak 17 years ago
finton 13 years ago
frikkie 14 years ago
lemonie 17 years ago
binnie 17 years ago
jjsonp 17 years ago
crapflinger 17 years ago
Kiteman 17 years ago
