How to Make a Spanner(wrench) Out of Pvc.
Introduction: How to Make a Spanner(wrench) Out of Pvc.
I've seen some pretty amazing pvc projects here and I thought I must do a nice and simple pvc project as my first instructable. It can be done in 5 minutes and costs about nothing.
Step 1: Required Stuff.
Materials needed:
Short piece of pvc pipe.
A source of heat (I used a tea candle).
A metal rod.
Bolts or brass fitting.
Pliers to hold the bolts.
Note: I'm having trouble adding notes to the image.So please bear with me. My problem has been solved thanks to Tool Using Animal.
Step 2: Forming Your Pvc
Just heat your bolt until it is extremely hot. Now take the pvc pipe and push it over the hot bolt.It will slowly start going on.Now cool and repeat on other side of pvc(only if you want to have a twin sized spanner).
Step 3: Drill and Add Handle
Drill a hole through the middle of your pvc and insert your metal rod. Your done. Now go and use your new pvc spanner/wrench.
Be the First to Share
    • Big and Small Contest
    • For the Home Contest
    • Game Design: Student Design Challenge
    24 Comments
    cgosh
    cgosh
    8 years ago on Introduction
    Technically, although this is a terrific idea, it's not a spanner. Check images.google.com to see some. They "span" a large gap.
    BTW, if this tool isn't tough enough to suit you but you still don't want to spring for a metal wrench, try wrapping wire or strong cord around the outside, and/or coat it with epoxy (try JB Weld brand, cures very hard).
    Hand-made tools. Gotta love 'em. Thanks for the idea.
    Oorspronklikheid
    Oorspronklikheid
    Yes maybe spanner is something that span a difference maybe not. Quite frankly I'm getting kind of sick of this , I posted this I'ble in '07 but every few years some twaddle nit picks on my choice of words. I want you to realise two things. Namely that i was 18 at the time of posting and did not know much back then and that I speak a whole different language than you! Yes i speak Afrikaans and in our language we only have an equivalent word for spanner and not wrench. The correct translation would be "ring spanner" as it is used it here.So the moral of my story is that people on the internet actually speak different dialects(imagine that) and that simply googling things may not prove accurate. Anyway I have provided pictures and you can immediately see what i am talking about. Arguing about language and grammar usage is secondary of nature as it only concerns itself with the transfer of knowledge and not the information contained within witch is clearly visible from the pictures I provided. Next time before you comment take a while to read what has been said already
    PetervG
    PetervG
    16 years ago
    So whats a spanner?
    Apples
    Apples
    Reply 16 years ago
    british english word for a wrench.
    servant74
    servant74
    Reply 15 years ago on Introduction
    Two nations separated by a common language! :) ... I wonder which famous person I misquoted that from.
    Gorfram
    Gorfram
    Reply 14 years ago on Introduction
    Oscar Wilde. He seems to be the source of all great quotes that aren't from Mark Twain or Winston Churchill. :)
    Phil B
    Phil B
    Reply 11 years ago on Introduction
    Actually, it was George Bernard Shaw.
    claudg1950
    claudg1950
    To follow up on this funny thread; may I quote British-Hungarian humorist George Mikes? He wrote (more or less): "According to the US Constitution, the official language of the United States of America is English. Regrettably, it hasn't yet been put into practice."
    Oorspronklikheid
    Oorspronklikheid
    I can't believe how this thread that started from a simple misunderstanding between two common language have steam rolled since the creation of this article and out of it has flown more wisdom than the original article itself. Good work everyone
    claudg1950
    claudg1950
    Thanks a lot. In fact we are just a bunch of guys bragging about how cultured we are....:-) Good 'ible anyway.
    Legolutionary
    Legolutionary
    I may be mistaken, but isn't that Mike Skinner? The Streets - Two Nations...
    holeman666
    holeman666
    a spanner is a tool wich you use to turn around bolts and nuts with, and you americans prefer calling it a wrench :)
    JakeTobak
    JakeTobak
    Reply 16 years ago
    I Googled "spanner" and it seems to be a wrench.
    finton
    finton
    12 years ago on Step 3
    Great idea! That would have been just the answer for spinning a nut onto a long bolt as I had to do recently. Instead I had to use a Crescent spanner (shifter, adjustable wrench, whatever) doing <180 degree turns once my socket set wouldn't reach any further. I'd be inclined to have some type of adaptor to connect it to an electric drill so one need not turn it by hand.
    lemonie
    lemonie
    16 years ago
    This type of tool is known as a 'box spanner'. PVC cannot take much torque, and that much is obvious. If you're using this on PVC nuts it'll have an advantage in not chewing them up. However, metal nuts will surely chew this tool up(?)
    binnie
    binnie
    Reply 16 years ago
    pvc will melt if you heat it. the nuts go bye bye lol
    jjsonp
    jjsonp
    16 years ago
    you can also heat the handle and melt/push it through the PVC if you don't have a drill handy. sometimes i've found melting a hole through PVC to be much more convenient than drilling, depending upon the application.
    crapflinger
    crapflinger
    16 years ago
    "back home" we had to turn off the water to our house at least once or twice a year in the winter because none of the pipe's were insulated (if we left the water on...the water would freeze and the pipes would burst...i love old houses)...well the only place to turn the water off was from the main "tie in" box to the city water supply..who sells wrenches for the contraption inside of that box? no one...how much did the city charge to come turn your water off/on when you wanted them to? about $100..IF they ever showed up...so we made our own wrench using roughly the same method as this instructable...and it worked great...
    Kiteman
    Kiteman
    16 years ago
    Do you pull the bolt back out to leave a hexagonal hole?
