Introduction: How to Make a Tech Deck Landing Ramp for Your Mega Ramp
This is another instructable for tech decks. I recently made an instructable for a tech deck mega ramp, this is the other part of that.
Step 1: Materials
you will need...
1. a pizza box
2. duct tape
3. paper and scotch tape(these might not be necessary see other steps)
4. tech deck mega ramp
5. a few small books for support
1. a pizza box
2. duct tape
Step 2: Shaping
First you need to cut off the top or bottom of the pizza box, you will only need one side. the landing ramp should really only be a foot or so from your mega ramp, otherwise it is too hard too land. The ramp shouldn't be to steep. It should be, at the tip, a 45 degree angle or less, it should not be any more than a 45 degree angle. The landing will not need duct tape because it is so much smaller and doesn't need to be curved as much.
Step 3: Supporting
Take a small leftover piece of the pizza box and put it under the slanted part of the landing propping it up at whatever angle you had it at. You can tape it to the ramp and to the ground with duct tape. THIS WILL LEAVE STICKY STUFF ON YOUR FLOOR only do that if you are willing to clean it up. Otherwise scotch tape a piece of paper to the ground and duct tape the support to the piece of paper. Then you will need to tape a side of the ramp to a piece of paper scotch taped to the ground directly without cardboard(the pictue will help). Then you should just slip a few books under the ramp so it doesn't bend.
Step 4: You're Done
If you didn't see the mega ramp instructable go here: https://www.instructables.com/id/Tech-Deck-Mega-Ramp/
