Introduction: How to Make a Timer With Notepad.
Open notepad.
Here's a base code frame that you can use to make a timer.
@echo off
color 0a
:1
pause
timeout 60
goto 1
color changes the color combination in the application file
timeout set the time in seconds
the :1 and the goto 1 loops the timer so that it stops and resets so you can start it again with a press of a button.
the @ehco off keeps the app from putting other stuff on the app screen to keep it clean and simple.
@echo off
color 0a
:1
pause
timeout 60
goto 1
Step 1:
save the file as a text file ".txt" in the desired location.
Step 2:
then save it again, but this time as a batch file ".bat" in the desired location.
Step 3:
run the batch file.
Step 4:
to edit open the text file, make your changes, save it as a text file, then save agian as a batch file.
Step 5:
now you have a timer.
