How to Make a Very Cheap Homemade Pop Filter
Intro: How to Make a Very Cheap Homemade Pop Filter
This is a very quick and easy way to make a homemade popfilter for recording vocals.
"A pop filter or pop shield is an anti-pop noise protection filter for microphones, typically used in a recording studio. It serves to reduce popping and hissing sounds in recorded speech and singing. It can also protect against the accumulation of saliva on the microphone element." -Wikipedia
STEP 1: Gather Materials
For this you need just a few materials:
- 1 pair Pantihose
- 2 spring clamps
- 1 wooden dowel (about 3 feet in length)
- 1 cardboard box
- Glue (I used wood glue)
- Scissors
STEP 2: Cut Apart Cardboard
Here I used a utility knife to cut away the top part of the cardboard box. I used used a pencil and marked the bigger part of the box so I knew both pieces would line up before I cut them apart.
STEP 3: Pantihose
Here you pull the panty hose over the inner cardboard ring. Then put a ring of glue around the outside. Slide the outer cardboard ring over the top of the inner. You also want to make sure that the pantihose are pulled tight before you glue it. Then let it set and have the glue dry.
STEP 4: Rod.
Here you take the scissors and basically score the rod. Just move them in a circle. I cut the rod pretty much in half. Once the rod is scored, then just bend it over a corner.
STEP 5: Add the Rod to Filter
Now you cut off the excess pantihose from the filter. Use the scissors to drill a small hole in the edge of the filter. Make sure you don't make the hole too big. You want the rod to barely squeeze into that hole. Once it's big enough push the rod a small way into the filter. You can even glue it if you want, but I didn't find it necessary.
STEP 6: Put on Mic Stand and Rock Out.
Now all you need to do is attach the filter to your mic stand. Here you can use the clips to adjust the height at the distance. I've read 2 inches from the microphone is standard but it's something you'll have to play with on your own to get a good sound.
Enjoy.
Enjoy.
17 Comments
a splosion 13 years ago
Thanks again!
xamox 13 years ago
Keep on jamming!
mxx 6 years ago
Great! I'm going to make a similar one, though a bit smaller, for a desktop mic.
stubbsonic 11 years ago
I did a version of this kind of pop filter with a set of embroidery hoops from a craft store (they come in different sizes). I fastened the hoops to a cheap mic clip so it could be positioned with a second mic stand. Your clamp method is clever!
ccncdc 12 years ago
dfedde 14 years ago
PsyOp 15 years ago
xamox 15 years ago
Gypsyman 15 years ago
guitarman63mm 15 years ago
DIY Dave 16 years ago
xamox 16 years ago
xamox 16 years ago
incorrigible packrat 16 years ago
btw If you can get hold of an old embroidery hoop, from a thrift store or somewheres, it might make for an even easier build...
xamox 16 years ago
GorillazMiko 16 years ago
LinuxH4x0r 16 years ago
