Introduction: Water Drop Macro Lens
In this instructable I will show you, how you can take really cool macro pictures with a drop of water as a lens for your smartphone / tablet.
We are putting water directly onto the smartphone / tablet, so don't do this, if you are worried, that it will cause damages. I am not worried at all, as I have done it a lot of times, but I won't take responsibility if something happens when you do it :)
I was really amazed how the pictures turned out, and I hope you will have just as much fun doing this, as I had making this instructable.
Let's go!
Step 1: What You'll Need
- A smartphone or tablet
- A cloth for drying your camera / spilled water - We are working with water and electronics at the same time, so you have to be careful!
- Headphones with volume buttons OR a bluetooth remote control if you have one - i got mine from a selfie stick... Don't judge me...
- Cotton swabs or a syringe
- Glass of water
- Something interesting to take macro pictures of
Step 2: There Are Two Ways to Do It
I am using my iPhone and my iPad to take these macro pictures.
There is two cameras on most of the phones out there. One on the front and one on the back.
Camera on the back
If you want to use your iPhone, i recommend that you use the camera on the back. The iPhone's front camera is too close to the microphone, so the water drop might run down there, and we really don't want that! The back camera is pretty much isolated from open spaces into the iPhone.
If you want to use the back camera, see next step.
Camera on the front
If you have a phone / tablet, where you are able to put a drop of water on the front camera, or if you think that you can handle a drop of water on the iPhone's front camera, I recommend that you use the front camera.
The water drop macro lens is much funnier and easier to use, if you use it on the front camera, because it is easier to control, and because there is glass covering the camera completely. I am using my iPad to take pictures from the front camera.
If you want to use the front camera, see step 5.
Step 3: Preparing the Camera on the Back
Place your smartphone flat, so that you can put a drop of water on top of the camera lens.
You can either use the syringe or the cotton swabs, but I prefer the cotton swabs. You can also use your finger, but you can't control that as good, as with a cotton swab.
Take the syringe or the cotton swab, and put a drop on the lens. Be careful not to put too much water on it. The camera has some sort of "ring" around it, that can hold the water in place. If you make the drop too large, the water will run off the phone, before you can turn it over.
Quickly turn the phone around before the water runs off.
Now we are ready!
Step 4: Using the Camera on the Back
I recommend that you put the phone on the edge of the cloth, so that you can tilt the phone closer to the object. In this way, you get more stability.
You can either use your headphones as triggers, or you can buy a selfiestick, if you don't mind losing your dignity ;)
The first picture is a GIF, where you can see, how I take my pictures. (I had to do it with one hand, because I used the other hand to record..)
Step 5: A Mosquito Larvae
We have a bassin where I managed to catch this small mosquito larvae. I am very impressed, that the macro lens could show such a detailed photo. The 2nd last picture shows, how close the iPhone could come without a water drop, and the last picture is with the water drop.
The first picture is a GIF, and you can even see something moving inside the larvae's body!
Step 6: Using the Camera on the Front
Use the syringe or a cotton swab to put a drop on top of the front camera.
Unlike the camera on the back, there isn't a "ring" around the front camera. This means, that the water won't be hold in place, and you can make a bigger variety of water drop sizes.
If you want to see, how the size of the water drops affects the pictures, go to next step!
This method is easier than using the camera on the back, because you can move the object back an forth, instead of trying to keep the whole camera stabilized. Take your object, and hold it close to the camera.
Another sweet opportunity of using the front camera, is that you can hold a flashlight above your object, and light it up from the back. I turns out to really cool, when you are doing it with leafs, because the backlight reveals the pattern inside the leaf much better. Check out the last to pictures to see the difference between the leaf without backlight, and the leaf with.
Step 7: Size Matters
The smaller the drop is, the closer you can focus on your object.
When you put the drop on the camera, be sure to put it right in the middle. Especially when you are making small drops.
The bigger the drop gets, the more it flattens out. When the drop flattens out, we lose the effect of a lens, as the drop has to be in a "dome" shape.
Try and see on the first picture, how the size affects the pictures.
Step 8: Please Share Your Photos!
Thank you for viewing this instructable!
I hope you liked it!
Please share your photos, if you try this. I can't wait to see them!
P. S. if you liked this instructable, I would be so happy, if you would vote for me in the Photography, Tips and Tricks Contest or / and in the Phone Contest.
Thanks!
