Introduction: How to Make an Archery Target
This target is very simple and only took me 20 minutes to make. You can change out the bottle to make your target bigger or smaller.
Step 1:
These are the materials you will need for the first few parts:
1)water bottle/container (this can be whatever size you want your target to be)
2)shredded paper (if you don't have a shredder than paper cut into small pieces will work)
3)water
Step 2:
Fill up your water bottle about halfway full. Then wet it down with water.
Optional: You can get something to stick inside your container to squish the paper down.
Step 3:
Repeat step 2 until the bottle is full.
Note: Make sure to water the paper down periodically. Soak it, don't flood it.
Step 4:
Once you are done filling the target you now need to drain it so that when you hit it water doesn't come shooting out.
Here are the tools you need:
1)an All (hole puncher)
2)Hammer
Step 5:
Your finished product!
Remember to be safe when using target.
I am not responsible for any injury or property damage caused by missing the target.
