Introduction: How to Make an INVADER Pop Up Card (Kirigami 3D) Video Game Greetings - TCGames [HD]!
About: Hi! I am a software developer who likes to dabble in creative projects in my spare time. On my page you will find post about my various hobbies and interests including origami, arts, craft, 3D Printing, progra…
Invaders galore!
Share on FACEBOOK: http://on.fb.me/15TrVYf
TWEET: http://bit.ly/15Ts5P6
REDDIT: http://bit.ly/16qHt5L
TUMBLR: http://bit.ly/10K8fhz
Download the FREE pattern here: http://www.popupology.co.uk/galleries/9/items/50
More about kirigami:
Kirigami (切り紙?) is a variation of origami that includes cutting of the paper (from Japanese "kiru" = to cut, "kami" = paper). It is also called "Kirie" (切り絵). From "Kiru"= to cut, "e"= picture.
Typically, kirigami starts with a folded base, which is then cut; cuts are then opened and flattened to make the finished kirigami. Kirigami are usually symmetrical, such as snowflakes, pentagrams, or orchid blossoms.
A difference between kirigami and the art of "pop-up" is that kirigami is made out of a single piece of paper that has been cut into a design. Pop ups can be made of several pieces glued together.
Mon-Kiri is the Japanese art of paper cutting.
¿Cómo hacer un árbol de corazones Pop Up Card ( Kirigami 3D) Saludos del día de San Valentín - TCGames [HD ] !
Esta tarjeta no fue diseñado por mí, pero ya que estaba disponible que pensé en compartirlo . Enjoy :) !
Más sobre kirigami :
Kirigami (切り 紙? ) Es una variación del origami que incluye el corte del papel ( del japonés " kiru " = cortar, " kami " = papel) . También se le llama " Kirie " (切り 絵) . De " Kiru " = cortar , "e" = imagen.
Típicamente , kirigami comienza con una base de plegado , que luego se corta ; cortes se abrieron entonces y se aplanan para que el kirigami acabado. Kirigami suelen ser simétricas , como copos de nieve, estrellas de cinco puntas , o las flores de orquídeas.
Una diferencia entre kirigami y el arte de "pop -up " es que kirigami está hecho de una sola pieza de papel que ha sido cortado en un diseño. Pop ups se pueden hacer de varias piezas pegadas .
Mon- Kiri es el arte japonés de corte de papel .
如何使心拉网证(剪纸3D )情人节问候树 - TCGames [高清] !
此卡不是我设计的,但因为它是可利用的,我想我会分享它。享受:) !
在这里下载免费的模式: http://kirigamiarts.blogspot.ca/2013/07/valentines-day-pop-up-card-tutorial_8168.html
更多关于剪纸艺术:
剪纸(切り紙? )是折纸的变化,其中包括切割纸张(由日本" kiru "=削减, "神明"=纸) 。它也被称为"基里耶" (切り絵) 。从" Kiru "=削减, "E" =画面。
通常情况下,剪纸艺术开始于一个折叠的基础上,然后将其切断,切削,然后打开并展平,以使完成的剪纸艺术。剪纸通常是对称的,如雪花,五角星,或兰花的花朵。
剪纸艺术和"弹出"艺术之间的区别在于,剪纸艺术是开出了一张纸,已切成设计。弹出窗口可以由几片粘在一起。
周一至滴是日本艺术的剪纸。
TCGames [एच.डी.] - दिल पॉप अप कार्ड ( Kirigami 3 डी) वैलेंटाइन्स दिवस अभिवादन के एक ट्री बनाने के लिए!
इस कार्ड में मेरे द्वारा बनाया गया लेकिन यह उपलब्ध था के बाद से मुझे लगता है मैं इसे साझा था सोचा नहीं था . :) का आनंद लें!
यहाँ मुफ्त पैटर्न डाउनलोड : http://kirigamiarts.blogspot.ca/2013/07/valentines-day-pop-up-card-tutorial_8168.html
Kirigami के बारे में अधिक जानकारी:
Kirigami (切り 紙?) ( जापानी " कीरू " = कटौती करने के लिए , " कामी " = कागज से ) कागज के काटने शामिल है कि origami के विभिन्नता है . यह भी " Kirie " (切り 絵) कहा जाता है . " कीरू " से = , कटौती करने के लिए 'ई' = चित्र .
आमतौर पर, kirigami तो कट जाता है जो एक जोड़ बेस के साथ शुरू होता है, कटौती फिर खोला और समाप्त kirigami बनाने के लिए चपटा कर रहे हैं . Kirigami आमतौर पर इस तरह के बर्फ के टुकड़े , pentagrams है , या आर्किड फूल के रूप में , सममित हैं .
