Introduction: How to Make an Origami Christmas Decorative Ornament - COFO Kusudama!
In this tutorial, I will show you how to make an origami Christmas COFO Kusudama Decoration (Modular 20 unit). Enjoy :D!
Origami: Christmas COFO Kusudama Decoration (Modular 20 unit)!
Designed By: Falk Brito
Instructions found on https://www.facebook.com/photo.php?fbid=510733888945832&set=a.301588319860...
Falk Brito's Facebook: https://www.facebook.com/falkbrito
Happy folding!
Tips: Take care of your folds at the beginning, and the rest should be fairly easy if you follow the tutorial exactly. Making careful folds, and making sure everything is properly aligned will allow you to get best results for the final product. This rule is something that should probably be kept in mind when making any origami model. Other than that, have fun!
Design von Falk Brito
Gefaltet habe ich die Module aus 3,8 x 5 cm Packpapier
du brauchst 60 Module für dieses Modell
du kannst aber auch variieren :-))
Der Kusudama wird mit Kleber fixiert !
Hier findest du Falk Brito : https://www.facebook.com/falkbrito
und hier das Diagramm :
Happy folding !
The Japanese kusudama (��; lit. medicine ball) is a paper model that is usually (although not always) created by sewing multiple identical pyramidal units (usually stylized flowers folded from square paper) together through their points to form a spherical shape. Alternately the individual components may be glued together. (e.g. the kusudama in the lower photo is entirely glued, not threaded together) Occasionally, a tassel is attached to the bottom for decoration.
Kusudama originate from ancient Japanese culture, where they were used for incense and potpourri; possibly originally being actual bunches of flowers or herbs. The word itself is a combination of two Japanese words kusuri, Medicine, and tama, Ball. They are now typically used as decorations, or as gifts.
The kusudama is important in origami particularly as a precursor to the modular origami genre. It is often confused with modular origami, but is not such because the units are strung or pasted together, instead of folded together as most modular construction are made.
It is, however, still considered origami, although origami purists frown upon using its characteristic technique of threading or gluing the units together, while others recognize that early traditional Japanese origami often used both cutting (see thousand origami cranes or senbazuru) and pasting, and respect kusudama as an ingenious traditional paper folding craft in the origami family.
For more read here: http://en.wikipedia.org/wiki/Kusudama
Happy folding!
Happy folding !
