Introduction: How to Make an Off the Shoulder Long Sleeve Dress With Belt
About: Learn how easy is to design your own clothes! The best Do-it-yourself videos on the web! Join me :D
Turquoise, black, or others colors you like. Make a beautiful, dreamy dress for spring! Imagine that you will the envy between your friends ;)
To make this dress you'll need: jersey or lycra, pins, sewing machine, scissors, measuring tape, chalk or a pencil.
Step 1: First Step
Picture #1 and Pictures #2: First of all pin the fabric and secure it
                                                 Primero antes que nada asegura la tela con los alfileres
Picture #3 ans Picture #4: measure how wide you want to be the sleeve. I did it 30 cm.
                                                Mide que ancho te gustaría que sea la manga. Yo lo hice en 30 cm.
Picture #5 and Picture #6: Then measure your shoulder and mark on the fabric
                                                Luego mide el hombro y marca sobre la tela.
Picture #7 and Picture #8: Start drawing the sleeve and then go turns the end of the dress
                                               Empieza a dibujar la manga y luego sigue dibujando hacia el final del vestido.
Step 2: Second Step
Picture #9: After you mark the shoulder, cut the fabric.
                    Luego de haber marcado sobre la tela la medida del hombro, corta la tela
Picture #10 and Picture #11: Now to cut the shape of the dress, make sure to pin the fabric close to the lines then you can start cutting
                                                    Ahora para cortar la forma del vestido, asegúrate de colocar los alfileres cerca de la línea para luego empezar a cortar.
Picture #12 and Picture #13: See how is a simple shape and how I cut leaving about 2cm far from the line
                                                     Mira que el molde es super simple y como voy cortando dejando 2cm de distancia de la línea.
Picture #14 and Picture #15 and Picture #16: time to sew the sides and sleeves of the dress. I use a straight stitch for this
                                                     Ahora es hora de coser los costados del vestido. Para esta ocasión utilize un puntada recta
Picture #17 and Picture #18: Make the hem on the neck line, then sew it with a straight stitch
                                                    Haz un dobladillo en la línea del cuello, luego cose con una puntada recta.
Picture #19 and Picture #20: You can add a belt also to contrast the dress :)
                                                     Puedes agregar un cinto también para darle un toque de contraste con el vestido. :)
Step 3: Result
Good Luck ;)
