Introduction: How to Make Flashing Police Lights With Sound
Heres an example
Step 1: You Will Need
For this project you'll need:
1 Piezo Element
1 Tri-color LED Or 1 Red LED and 1 Blue LED
Some jumper cables
1 Breadboard
1 Arduino or suitably similar thing (I use the arduino Uno)
Optianal:
Resisters (I dont know the strength needed cause i dont use the for this project)
Step 2: Wirering
Wirering:
1. put your Tricolor LED in your breadboard.
2. run a wire from the led ground to the arduino ground
3. run a wire from the led red to port 9 on the arduino
4. run a wire from the led blue to port 10 on the arduino
5. put your piezo element in the breadboard,
6. run a wire from piezo ground to the row with the led ground
7. run a wire from the positive side of the piezo element to port 11
8. run a wire from the positive side of the piezo element to port 6
Okey thats the wirering done :D
Step 3: The Code
Now assuming you know how to insert and upload the code i am just going to insert it here:
// By Jonas P. Hyatt
// Thanks to Tom Igoe and Dave1324
int ledDelay = 50;
int redPin = 9;
int bluePin = 10;
void setup() {
pinMode(redPin, OUTPUT);
pinMode(bluePin, OUTPUT);
void loop() {
digitalWrite(bluePin, LOW);
delay(ledDelay);
digitalWrite(redPin, HIGH);
delay(ledDelay);
digitalWrite(redPin, LOW);
delay(ledDelay);
delay(ledDelay);
delay(ledDelay);
delay(ledDelay);
noTone(11);
tone(6, 440, 200);
delay(ledDelay);
digitalWrite(bluePin, HIGH);
delay(ledDelay);
delay(ledDelay);
delay(ledDelay);
delay(ledDelay);
noTone(6);
tone(7, 494, 500);
noTone(7);
tone(11, 523, 300);
4 Comments
7 years ago
You are awesome,thanks mate!
8 years ago on Introduction
You said
" 7. run a wire from the positive side of the piezo element to port 11
8. run a wire from the positive side of the piezo element to port 6 "
What's that supposed to mean? I don't understand.
The figure shows that positive(red wire) is connected to digital pins #6 and 11.
9 years ago on Introduction
this was cool, thank you for sharing,
made it with my brand new arduino UNO, and it worked first time :D
