Introduction: How to Make Homemade Napalm
WARNING: YOU CAN HURT YOURSELF OR OTHERS MAKING THIS INDESTRUCTABLE
I AM NOT RESPONSIBLE FOR ANYTHING THAT YOU DO IN RESULT OF READING THIS.
NOW LETS GET STARTED.
To make Napalm you will need:
Lots of Styrofoam
an empty aluminium can
some gasoline
a big nonflammable surface you can destroy
Step 1: What to Do.
Fill the can about 1/2 full of gasoline
Crumple the Styrofoam into small chunks
Put the chunks in the can and use a stick to stir till the foam melts
Repeat until there is a grayish goo in the can. It has to be thick.
Be sure to stir with a stick since gasoline is harmful to skin.
Step 2: The Fun Part
Take a stick and dip it into your napalm.
Then set in on fire using a lighter.
Then take it and fling the burning napalm on your nonflammable surface.
Wait for the fire on the stick to die out, if you don't and dip it in the can you will set ALL of you napalm on fire (its not dangerous) and not have any fun.
COMMENT PLEASE
This is what the stick should look like.
COMMENT PLEASE
