Introduction: How to Make Lambent Light
lambent light is the rapier used by asuna in sword art online
this is the easiest way to make the sword and most cost effective to make this or almost any sword
PS its my first instructable so constructive advice would be helpful
Step 1: Stuff You Need
1. cardboard- to form the base
at least 40inc long
2. craft knife
3.card/paper
4. lollipop sticks 0.99p
5. glue - PVA and hot glue gun
6. pencil, ruler
7.scissors
at least 40inc long
2. craft knife
3.card/paper
6. pencil, ruler
7.scissors
Step 2: Template
you very lucky person I've already got some. print these out on a4
note the template that looks like a semi circle don't trace onto card
after you print those out you can cut then out and trace them onto card
Step 3:
after you have traced out the sword remember its 40incs long so you have to fill in the gap between the point and rest of the blade
take your time while cutting out the sword with your knife make sevral cuts to give you a clean cut
Step 4:
now to strengthen using your lollipop sticks start gluing -hot glue- them in place layer then like bricks along the center of your sword do two layers of this and it should become much stronger
Step 5: Covering It With Paper
basically what you are doing is drawing around your sword onto paper and using PVA glue to glue it onto the main structure do this a few times so you get a clean look.
rember to draw bigger than the sword
Step 6: That Ring Thing
this is to be cut out onto card and fits onto the cross guard use eiter PVA or hot glue to do this
Step 7: Finished
hoping that you followed you should now have a sword that replicates that of the anime just not painted if you want to paint it then there is a reference image above
