Introduction: How to Make Minifigure Heads and Acessories
this is a quick and easy craft you can do with stuff you probably already have. you can also try to make blocks out of cardboard using this technique you can also try to make hair for your minifigures with sculpey.
Step 1: Stuff You Need.
you will need
glue,
paper.
scissors.
paint or permanent markers.
a straw.
a bead that is round and large enough to fit the straw through the middle.
Step 2: Head.
so what you're going to do is put some glue in the middle of the bead.
Step 3: Head
add the straw.
Step 4: Head
and cut the straw to be the size of the little peg thing on top of spidey's head.
Step 5: Put on the Head.
I painted mine, guess spiderman doesn't like getting decapitated :)
Step 6: Acessorize
now for the accessories. take your piece of paper and roll it into a tight tube shape. make sure it fits in the minifigures hand. and then glue and re-roll it.
Step 7: Decorate
you can decorate the acessories to look like different things. I made a mug of coffee. you can also use toothpicks to make acessories.
