Introduction: How to Make Pendants and Charms From Old CDs
Step 1: Material
Old CD's
A sharpie
A dremmel kit with different bits
Protective glasses and gloves
A beading, wiring kit
This is a very messy project, so I suggest you work outside or in a workshop. Hot pieces of plastic fly away a lot while carving the shapes, so you will REALLY need gloves and glasses.
Also, I noticed that different brands and types of CD's / DVD's react differently to the carving tools. Some of them lost their backing, or separated in two differents layers. Make more pieces than you need and expect some of them not to come out the way you want them to.
Step 2: Choosing and Marking Images Onto the CD's
To choose the perfect shape to make a pendant, think stencil. Choose an image that doesn't have any unattached, loose parts. Unless you are much more skilled than me with the power tools, try to choose one that is not too small or detailed.
I printed my images and cut around them, then stenciled them unto the CD's.
Step 3: Start the Carving!
I don't have many pictures of how I cut them, because, again, I only have two hands.
I started by using a big bit, and making an approximative cut around the shape. Once the piece got separated from the CD, I used the same bit to smooth the contour of the shape.
I then switched to a smaller, drill type bit. I used it to mark the details (eyes and mouth of the hello kitty, smaller grooves in the dragonfly's wings, and make the pendant holes.)
I chose a top shaped bit to smooth the edges of the shape even more, and remove the bits of melted plastic that remained on the edges.
This was mostly a trial and error method, since I had never used a Dremmel before. This was quite an easy project, and I am sure that if you prepare a couple of extra pieces to practice on, you will find a technique that will work perfectly for you.
Step 4: Finish and Create!
Thank you for reading, hope you enjoyed !
Well sorry about the poor quality of the finished product pictures, but they are really hard to capture properly because of the glare.
