Introduction: How to Make Warm House Slippers
I needed just a simple slipper to keep my feet warm on our cold cement Floored kitchen and bathroom. I got this idea from the Pink Slipper Project.
Step 1: Supplies
Step 2: Step 1: Bottom Pattern
Make your pattern by outlining your feet on the top side of the outer fabric. Make sure to use both feet for the pattern so you will not end up with two left feet!
Drawing the line approximately one inch from your foot all the way around.
Step 3: Step 2: Cutting
Using the patterns you drew of your two feet, cut your materials as follows:
Right Foot:
Cut 2 - Primary Fabric
Cut 3 - Iron on Batting
Cut 1 Sole
Left Foot:
Cut 1 Sole
Step 4: Step 3: Top of Slipper
Create the pattern for the top of the slipper using the cut bottom pieces as a guide cutting on the fold.
Draw the toe about1 in larger and bring it down about a half way to three-fourths down the top foot section on the primary fabric
Step 5: Step 4: Cut Toe
Cut out the toe fabric as follows using your pattern:
Cut 2 primary fabric (On the fold)
Cut 2 batting
Step 6: Step 5: Layer Order
Lay the fabrics for the bottom slippers in the following order starting from the bottom:
1. sole
2. primary fabric
3. layer of batting
4. layer of batting
5. layer of batting
6. primary fabric
Step 7: Step 6: Pin
Pin the bottom layers in order.
Step 8: Step 7: Toe Arrangement
Put the batting between the folded cut primary fabric. Press.
Step 9: Step 8: Connect Top to Bottom
Pin the top of slipper starting at the tip of the toe.
Pin all the way around the toe on both slippers.
Step 10: Step 9: Sew Together
Sew all the way around both slippers with a straight stich reinforcing the stitching where shown on the photo.
Step 11: Step 10: Trim the Edges Close to the Seams. and Enjoy Your New House Slippers!!!
Trim the edges with your scissors close to the seams all the way around the slippers
And enjoy your new house slippers!!!
Sew Warm Challenge
2 Comments
4 years ago
Great job of a fast diy slipper.... Brilliant. Can't wait to try it.
9 years ago on Introduction
This is awesome thank you!
