Introduction: How to Make Your Own Storage Heater From Strawcrete and Stone - Part 3 the Wall. Brico Ecolo Radiateur - 3. Bricolaje Calentador Ecológico - 3.
With the strawcrete starting to dry, I took off the mould and left it for a few days to let the air circulate around it until it had hardened.
I then placed it in position on the hearth and with the wood stove still in place, began to build wooden shuttering around it to guide me in building the stone wall.
I then removed the stove and set two more guide planks across the front of the shuttering.
Con la strawcrete empezando a secar, le quité el molde y lo dejé por unos días para que el aire circule alrededor de ella hasta que se endureció.
Entonces coloqué en posición sobre la chimenea y estufa todavía en lugar, comenzó a construir alrededor de encofrado para guiarme en la construcción de la pared de piedra.
Luego me quité la estufa y puse las otras dos tablas de guía a través del frente de la forma.
La plaque commençant à sécher, j'ai enlevé le moule et la laissée pour quelques jours pour que l'air circuler autour jusqu'à ce qu'elle ait durcie.
Je l'ai alors placé en position sur le foyer et le poêle à bois toujours en place, j'ai commencé à construire des coffrages autour pour me guider dans la construction du mur de pierre.
J'ai ensuite retiré le poêle et mis deux autres planches à guidage à travers l'avant du coffrage.
Step 1: It's All in the Planning! Todo Está En La Planificación! Tout Est Dans La Planification
The next stage was to gather together enough well shaped large stones and also smaller stones for infilling. These were then washed and dried.
Another long-term plan, which I carried out before I left the UK some years ago was to put myself on a bricklaying course. I had a job teaching maths in a college in the evening, where they ran an excellent course with great tips on using lime mortars and making your own fire cements, so I found time to do this and was really glad I did! Ironically I have never worked with brick on this house because everything is built in stone!
We carried all the stones in and arranged them in various shapes, in particular good corner pieces, even so it was a bit like doing a jigsaw puzzle without the box!
La siguiente etapa fue recoger piedras grandes junto bastante bien formados y piedras más pequeñas de llenura. Estos se lavaron a continuación y se secan.
Otro plan a largo plazo, que llevé a cabo antes de salir del Reino Unido hace unos años era asistir a un curso de albañilería. Yo tenía un trabajo com enseñando matemáticas en una universidad en la noche, donde se quedaron un excelente curso con grandes consejos sobre el uso de morteros de cal y hacer sus propios mortero refractario así que encontré el tiempo para hacer esto y estaba muy contenta de haberlo hecho! Irónicamente nunca he trabajado con ladrillo en esta casa, porque todo está construido en piedra!
Realizamos todas las piedras y los colocamos en diversas formas, en particular, las buenas piezas de esquina, así que era un poco como hacer un rompecabezas sin la caja!
La prochaine étape était de recueillir des grosses pierres bien carreés et les plus petites pierres pour remplissage. Elles ont ensuite été lavées et séchées.
Un autre plan à long terme, qu'a eu lieu avant de quitter le Royaume-Uni il y a quelques années - de suivre un cours de maçonnerie. Je avais un emploi comme prof de math dans une université la soirée, où il y avait un excellent prof de maçonnerie, pleins de bons conseils de l'utilisation de mortiers de chaux et de faire votre propre mortier réfractaire, j'ai trouvé le temps de suivre le cours et j'étais très heureux de l'avoir suivi! Ironiquement, je n'ai jamais travaillé avec des briques dans cette maison ici, parce que tout est construit en pierre!
Nous organisions toutes les pierres, en particulier de bonnes pierres d'angle, donc c'était un peu comme faire un puzzle sans boite!
Step 2: The Build. La Construcción. La Construction
and finally....
y finalmente....
et finalement....
Step 3: We Have Ignition! Encendido! Allumage!
This project was filmed and in detail but if you would like to
supplement this by reading about the project and seeing step-by-step pictures of the 'the Build' then please feel free to visit The Green Lever and also to ask questions and/or leave comments either here or on the blog.
All the very best,
Andy aka The Green Lever - Organikmechanic
El proyecto fue filmado y en detalle, pero si desea complementar esta leyendo sobre el proyecto y ver fotos paso a paso de la construcción entonces no dude en visitar The Green Lever y también para hacer preguntas y / o dejar comentarios, ya sea aquí o en el blog.
Todo lo mejor,
Andy tcc The Green Lever y Organikmechanic
Le projet a été filmé et en détail, mais si vous souhaitez en savoir plus sur le projet et de voir étape par étape des photos de la construction, alors ne hésitez pas à visiter The Green Lever et aussi de poser des questions et / ou laisser des commentaires soit ici ou sur le blog.
Tout le meilleur,
Andy dit The Green Lever - Organikmechanic
