Introduction: How to Mix 2 Stroke Gas
About: i am a kid who likes to make stuff out of metal and likes stick welding and putting weedeaters and chainsaws on bicycles. i own a 70 amp stick welder from princess auto and many small 2 stroke engines
hi this is my second instructable so please forgive me if i made a mistake.2 stroke gas is used in many things from weed eaters to motor cycles.I will show you how to mix it for a weed eater. My weed eater has a 40 to one ratio. if you have sone thing witha different ratio i will put upa chart for different ratios.
Step 1: Materials
Materials
ECHO 2 stroke fuel mix (best one i tried)
1 gallon gas can
gas
Where to buy the stuff
gas can -canadian tire
ECHO 2 stroke oil- home depot
gas- gas station (duh)
Step 2: How Much Oil to Add
well this depends on the fuel ratio written on the fuel cap. I am also putting a chart up so it is a lot easier.
Step 3: Final Notes
to mix put half a gallon of gas in the gas can put in the oil be accurate depending on the ratio
after that fill it all the way up to the line again be accurate.
if you live in the US use the pump meter.
