Introduction: How to Pack a Bike With S&S Couplers
My bike has S&S couplers (also known as S and S Machine Bicycle Torque Coupling) that allow it to be broken apart and packed into a normal-sized checked luggage box that flies at no additional charge. Getting it to fit is always a challenge, so I took photos to help me remember.
Your S&S-enabled bike will probably pack in a slightly different configuration, but you can still use this as a starting guide.
Step 1: Disassemble Bike
Take off the brakes, the rear deailleurs, the cranks, the handle bars, and fork.
Step 2: Fork and Front of Frame
Cover the frame with pipe insulation to protect the paint. Place the support bases, fork, and frame.
Step 3: Rear Wheel
Take the tires off both wheels, and place the rear in with the cassette facing down.
Step 4: Cranks
Wrap up the cranks and chain rings in a plastic bag, and pack them.
Step 5: Seat and Rear Frame
Place the seat and rear frame section.
Step 6: Front Wheel
Place the front wheel.
Step 7: Handle Bars
Fit the handle bars in.
Step 8: Tires and Finish
Squeeze the tires in. Place the top parts of the supports, add in the remains pieces, and carefully check if the box closes.
I always try the pack my bike the night before flying, to ensure I have time to do it properly.
8 Comments
11 years ago on Introduction
Are there any diy S&S couplers ? those things are Way costly . Love to be able to do that with a similar cheaper pipe connector .
12 years ago on Introduction
Hopefully the expiration of Steve-Frank Smilanick's patent 5586652Bicycle torque coupling in 2013 will make these couplers more readily available. They're extremely clever, but currently apparently only available to qualified bicycle frame builders. Which frame does your bike use? Also, are the bottom portions of the white supports attached to the bottom of the case somehow? Thanks for the clear pictures and detailed steps.
Reply 12 years ago on Introduction
My frame is custom-built. The white supports are not attached to the case, they are fit in wherever there's space.
13 years ago on Introduction
How do you ship a regular bike?
Reply 13 years ago on Introduction
I've shipped other bikes in large cardboard boxes.
I've heard by a bunch of people that they treat large cardboard boxes not very nicely and you can end up with something broken.
In fact, once when shipping my bike in a cardboard box on an airline, one of the chainrings got badly bent. Fortunately, it was on the return flight after my bike trip.
14 years ago on Introduction
Wow, Houdini probably wouldn't be able to fit a bicycle in a luggage bag that well. Good stuff chap. -Punk
