Introduction: How to Prepare Your Alpine Skis for Skiing
Hi, this is my first instructable. I've been preparing my Alpine skis for years and I thought it would be nice to share this with you.
I live in the French Alps and I think that preparing the family skis myself allows me to spare money.
Preparing your skis consist of :
- Sharpening the edges of your skis
- Waxing the sole of your skis.
The tools you will need are :
- A file
- Sanding paper
- An Iron
- Wax
- A Wax Scrapping tool
- A workbench
Step 1: Set Up Your Workbench
I use to put two wood boards maintained by clamps on my workbench in order to maintain my ski. Thus when I work on it, it does not move forward nor backward.
I also attach the ski-shoe to the ski, so the automatic stopper is lift-up and it won't be on my way when working.
I don't rely on rubber or cord to maintain the stopper lift-up, because the spring is strong and if your rubber or cord breaks the stopper would be released very strongly and may hurt you severely.
Step 2: Sharpen Your Skis Edges
Sharpening the edges allows to remove the rust, and will improve the grip on the snow.
For doing this I use a file. Some prefer to use sanding paper. The file goes faster to do the job.
But remember, you have to go always forward and backward. And you have to sharpen both the side on the sole, and the side perpendicular to the sole. But always back and forth !
Step 3: Prepare the Sole for Waxing
During the last winter, your skis have experienced some scratches and dents. So the sole may be uneven.
It's time to sand the sole whith sanding paper. I use grit 80. Remember to sand always back and forth.
When you slide the palm of your hand over the sole, you should not feel any plastic bits.
When the sanding is done, wipe the dust with a clean rag.
Step 4: Wax the Sole of Your Skis
In order to wax you skis you will need :
- An Iron
- Wax
First set you Iron to Wool (Its a not too hot temperature). Try to melt a little wax and let it on the Iron, the wax should not burn.
When the temperature is set, let flow wax drops all along the sole. Then you can gently iron your sole in order to melt the wax and create a layer on top of the sole.
Step 5: Scrape the Exceeding Wax
Here we are going to remove all the exceeding wax we applied before.
To do this we need a scrapper tool. It's a thick piece of acrylic. You can buy it or make one if you want.
Scrape the exceeding wax moving the scraper tool backward and forward on the sole, and look at your ski sole under the light to check if there is more wax to scrap.
You can also slide the palm of your hand over the sole to check if it's even.
Finally, gently clean the scraps.
Step 6: Finished !
Well, you're done.
You have almost brand new skis.
And you are ready for great snow days.
Enjoy !!
