Introduction: How to Put a Custom Image on Your Xbox 360 Dashboard.(Pre Fall 08 Update)
In this instructable im going to show you how to put a custom image as your background on your xbox 360.
there are the same steps for doing this with the new and old dashboard. when i get a chance i will update the whole thing with new pictures.
Step 1: What You Need
To do this instructable you will need a few things:
a usb memory device
computer
xbox 360
an image
a usb memory device
computer
xbox 360
an image
Step 2: The Image
You should have an image that will fit over the whole dashboard.
A 7X7 inch picture will fill the whole main dashboard but will not fill whole menus like your videos list.
To make the picture cover every thing I would use a 10X7 inch picture.
Step 3: Format
When you save your picture to your usb device as a JPEG. JPEG is the only format i found that works well.
Step 4: Plug It in Plug It In
Plug you usb device in to your xbox. Not hard stuff here.
Step 5: Media Blade
Go to the media blade then pictures.
Step 6: Saving
press A on pictures then chose portable device. Hilight the picture you want and press Y.
Step 7: Are You Sure?
This will set the picture as the background. Are you sure you want to use this picture?
To change the background later, open xbox guide, select personal settings, and select themes.
Yes use this picture.
Step 8: Done
there you go your done. The picture applies to every blade except the guide blades and the marketplace blade.
