Introduction: How to Remove Most of the Seeds When Cutting Up a Watermelon
Step 1. Cut both ends off the watermelon.
Step 1: Cut Lengthwise
Now make cuts lengthwise about 3-4" deep and 4" apart.
Step 2: Break Along Seed Line
Step 3. Now hit the melon along one cut strip to break along seed line.
The rind will be about 4-5 mm lower then the other strips. Break off the strip.
Step 3: Remove Seeds
If all was done right, your strip should have broke on the seed line.
Take a spoon and scrape the seeds off. Don't worry about removing some of the melon around the seeds because it is usually overripe and mushy anyways. Some people think this wasteful but it is an undesirable part of the melon.
Step 4: Slice to Serve
Once seeds are removed cut up the remainder of the strip into pieces to serve. Repeat the process for each remaining strip.
As you continue you will notice that the center of the melon is remaining. Clean the seeds off it and cut it up. This center section is the prime part so put it in a separate bowl and save it for yourself.
104 Comments
11 years ago on Introduction
I cut my watermelon in half and eat it with big spoon. I eat the seeds too, seeds are so tastey to me. :D
14 years ago on Introduction
that is the best part of being the cook, you have to see if it was cooked correctly ;)
Reply 11 years ago on Introduction
I always thought the best part of being a cook was being able to taste, taste, taste it as it is being made, until it was perfect :-)
12 years ago on Introduction
jesus, chill on the post-war... its a watermelon.(which are very good in my opinion.) :) spread the \m/ DEATH METAL \m/ lolz
12 years ago on Step 2
I agree with gmichaelt. Since the process of "hitting the melon" is applying force at one point, it is confusing as to whether cokecola means "hit down (looking at the picture above) on the watermelon anywhere along the strip on top", or whether he means "hit the melon on one of the ends from left to right (looking the the picture above), with the blow displacing a section of the watermelon.
13 years ago on Introduction
I hate seedz!! KILL ALL THE SEEDS !!
13 years ago on Step 4
Slice it however you like - you spit the seeds out as you eat it. Great contest when kids are involved and takes no scientific knowlege whatso-ever. Otherwise you are wasting the best part of a tasty melon.
14 years ago on Step 3
but thats my favorite part of the melon :O its all gooy and sweet...
14 years ago on Step 2
It states "Now hit the melon along one cut strip".
Much appreciated; I'll be sure to try it out next time I'm within reach of a whole watermelon. Yum! I'd suggest --most generally-- that authors here get used to thinking in 3- and 4-dimensions, and write their instructions in anticipation of them being read by someone who - or something that - does not have all the materials to hand. More particularly, in Step 3 --which appears as Step 2 by the site's lights-- you (cokecola) say: "Now hit the melon along one cut strip to break along seed line." This directive is not entirely clear; it isn't unambiguous with respect to the line along which the blow is delivered. Is the blow axial/parallel to the axis of the watermelon? Or radial/perpendicular to the axis? It might not make a difference functionally, but I'm not in a position to perform a practical check, as the watermelon I have is only an abstraction...
14 years ago on Step 4
Why not just cut off one end then stand the melon on that end on a cutting board or in a plate. The next step is to cut off the other end while the watermelon is standing with one end on that plate. You then see the seed line from one end this eliminates all the guesswork and then you take a knife or round device like a round cutter and run it from top to bottom of the melon throw the center out or cut it into small chunks and plant those seeds for your next years garden. then cut the other piece in halves or quarters or more to serve. You idea is a good one however and by the way has anyone ever xrayed a watermelon sorta like a mri on a melon to determine where or if the seeds actual locations can be determined for any melon just by studying the grid patterns on the outside of the melon perhaps these are related.
Reply 14 years ago on Introduction
No, no, no! Here it is: Why not just cut off one leg, then stand on your other leg while you hold the melon up in the air like you're waving a big round heavy green melon-land flag? The next step is to find a friend with a machete and a good pitching arm (and two legs). You then see that he can get a running start when he pitches the machete at the watermelon, so you hop up and down while he takes the device like a machete and flings it curve-ball-style right towards the center of the melon and --because he's also a magician -- the blade spins down like a ninja and slices the thing through the middle, twists in one decisive motion and carves the seed ring right outta the center, and those seeds fly out into the garden and plant themselves a watermelon tree. This idea is a good one, by the way, because when the watermelon tree is grown tall , you can cut yourself a branch and use it to fashion a brand new leg for yourself, and then the next time you need the seeds sliced out of a watermelon, you won't have to hop, so your friend the pitcher-magician can skip the curveball and just throw a regular old fast one. Moral of the story? "When you gots a magician, you don't need no MRI." Happy Holidays! ;)
haha
In response to Blitzy. Thanks but no thanks for your critical view. Do you think maybe my instructions are based on experience? It is easier to cut the ends off with it laying down. The seedline curves like the rind so there is no "eliminate all the guess work" . Your comment, "You idea is a good one however and by the way has anyone ever xrayed a watermelon" sorry you should have stopped at "You idea is a good one" and left it at that.
1) yes it is easier to cut both ends off while it's lying on it's side. 2) No you don't need to guess, seeing the end you are better off than just guessing a depth, knowing it curves. It is easier to cut the sides with it on the end once the end was cut. 3) Thank you for your instructable. 4) Be nice, don't be an a _ _ .
Reply 14 years ago on Step 4
Thank you for your constructive comment.
agreed!
come on guys, Cokecola just had his watermelon technique put down, and was a little upset. Blitzy, if you think a different technique is better, make an instructable. no one like 3-page comments, especially when you criticize their skills. elocin277 and ac-dc, on instructables there is such thing as a "Be Nice" policy. If you don't like a comment, you can flag it and it will be dealt with. to quote forrest gump, "That's all I have to say about that."
Jeff, I completely disagree. It would be much better for there to be only one instructable for each of the 80 gazillion possible topics, with all participants' comments contributing to either the best solution or at least offering different alternatives and perspectives. Instead we have people that are essentially trying to censor everything, as if we should just pretend there are only positives and no negatives to any instructable. The ONLY way to know what works best is to contrast with that which isn't best. Sorry but any sane person considers the negatives aspects of anything, and communicatively shares information. There's nothing "nice" about censoring information, nor would it be manageable for everyone to clutter sources of information with large amounts of redundancy. I hope you think about these factors and realize the ultimate goal which isn't a tribute to niceness, it's instructing. The odds are that nomatter who starts a topic, there are bound to be other individuals who have good contributory ideas that improve upon the original idea. That's how we humans built up the world and evolved by sharing information. It wasn't by being nice alone, nor by being nice at the expense of sharing information.
Wow coke, did your mom not hug you enough or something? What a jerk you are!
