Introduction: How to Remove Window Tint for Under $30
In this instructable, I'll cover how to remove window tinting from your car windows. It takes about 5 minutes for side windows and 15 for a rear window.
Let's get started!
Let's get started!
Step 1: Gather Your Supplies
You're going to need some stuff.
1 - Razor Blade ($1 for a 5 pack)
1 - Upholstery Steamer ($29 at the store at most)
1 - Set of Gloves (you should already own these)
Pretty short list. Make sure the gloves are heat resistant. I'm using Nomex Aviator Flight Gloves with a leather lining. The Nomex won't melt from the heat and the leather protects my hands from direct contact. Also, it's better to get a steamer with a hose and head, it's easier to work with.
Why steam? The glue from window tint comes off MUCH easier with heat. You can use a heat gun or a hairdryer, but to transfer heat the fastest into the glue I used steam. When the water molecule in the form of steam lands on something, it changes from a gas to a liquid. When it does this, it transfers all of that extra energy to keep it in gas form into the object it lands on. Using steam like this, you can transfer heat into stuff that you can't (or don't want to) light on fire but need to make really hot. This is also why steam will burn you really bad and you need to wear gloves while doing this.
Step 2: Begin!
Now, fire up the steamer and start steaming one of the top corners of the tint. Get it nice and steamed up, then use your razor blade to lift up the corner and grab it with your gloved fingers.
Step 3: The Magic Happens
Now slowly pull on that corner while working the steamer underneath the tint to create a little steam hood. Try not to let the tint get back on the window because it will stick again, then you have to take it off again. Continue this all across the top of the window, then work downward. When you reach the bottom, roll the window up and finish it up.
Step 4: You Done!
The process goes pretty fast. I would also recommend not breathing in the steam; it smells like glue and is probably bad for you. Just throw the tint away when you're done. If there's any left over glue on the window use some Windex with ammonia and a razor blade to remove it. When I did mine, there was no glue left at all.
