Introduction: How to Run TASM and Compile X86 Assembly Program in Windows 7 64 Bit Version (Including the Removed Commands in Windows 7 64 Bit: Edit and Debug)
How to Run TASM and Compile x86 Assembly Programs in Windows 7 64 bit Version (including the removed commands in Windows 7 64 bit: Debug and Edit)
Step 1:
1. Go to Start, and My Computer. Click on (C:) Local Disk C (or any desired location you want).
Step 2:
2. On the directory, create a folder and name it TASM ( or any name you want).
Step 3:
3. Download this file: https://drive.google.com/file/d/0B__kdfmfDbTLbGE4ZlRlRVJGaG8/view?resourcekey=0-J5i_vTMK91ZpuP18b5wZvQ
Step 4:
5. Extract the contents of the .zip file.
Step 5:
5. Copy the extracted files to the folder TASM (or to the folder you've made awhile ago). Also, don't forget to extract the DEBUG125.zip to the same folder.
Step 6:
7. Download DOSBOX here.
Step 7:
8. After installing the DOSBox, run it and type the following lines:
MOUNT E C:\TASM
E:
If you chose a while ago a custom drive besides the directory of C:
LET X be your drive letter:
MOUNT E X:\TASM
E:
Step 8:
9. Put your assembly code (e.g <your filename>.asm) in the same directory where you installed TASM and TLINK and run it by typing:
TASM <yourfilename>
TLINK <yourfilename>
Step 9:
10. The executable file is located in the folder TASM or your chosen directory. You can run it as it is or via CMD by typing <yourfilename>.exe
Step 10:
Extra (Optional):
11. The debug command was deleted in Windows 7 64 bit machines. The file that you've downloaded and installed has the 'debug' executable files. Now, you can run it via DOSBox by typing in DEBUG or DEBUG <your+executable+file>.exe.
Step 11:
Extra (Optional):
11. The edit command was deleted in Windows 7 64 bit machines. The file that you've downloaded and installed has the 'edit' executable file. Now, you can run it via DOSBox by typing in edit.
This feature is not really that important in programming assembly because you can write your codes in the notepad or any text editor applications.
1 Person Made This Project!
- GreatStudentEdo made it!
20 Comments
2 years ago on Step 3
Link is expired
Question 3 years ago on Introduction
When I install the dosbox....after I open, it does not opens.....why???
Plz tell me quickly
6 years ago
i followed tutorial and everything went according to it till step 8 but when i wrote TLINK M (split file name in my case ) it gives following error as shown in screenshot attached with it
split.obj : unable to open file
why is it so ? can anyone help me fast please ???
thank in advance
Reply 4 years ago
u have to copy the file to the c drive ex:abc.asm to c drive
5 years ago
Thanks
6 years ago
A few days ago, i got a windows 7 key from one page: https://plus.google.com/103156713044838092165/post... . After i use the key. Key not only work but it is genuine. Hope also can help you.
6 years ago
thank in advance
6 years ago
Personally recommend you going: www.cdekey.com, to get product keys for your windows 7,keys in this site are of good quality and in low price.
6 years ago
ty a lot man u saved my life
6 years ago
unable to download the file from file URL given in step 3.
7 years ago on Introduction
I can not see the progress of the Floating point registers. When I use RN after any Tracing of any Assembly instruction I can not see a modification in the ST registers. However the memory is modified correctly.
every-time I try to assemble my program I get a message saying illegal command tasm.
you need to be in same path as the TASM.EXE
example - compile a small program inside a folder
c:\tasm\example\3dcube> ..\..\tasm.exe points.asm
c:\tasm\example\3dcube> ..\..\tlink.exe points.obj
-- now there should be an exe file
Very useful tutorial. Keep up the good work.
7 years ago on Step 2
8 years ago on Introduction
Hi Nice :-) You can use D-Fend-Reloaded to
D-Fend-Reloaded is a frontend for DOSbox (version 0.74)
See my instructable:
https://www.instructables.com/id/DOWNLOAD-TURBO-PASCAL-71-AND-RUN-IT-ON-WINDOWS-SE/
9 years ago on Step 8
this program cannot run in dos mode please help me bl_bilal@yahoo.com
9 years ago on Introduction
i have a complete collection of 32 bit assemblers
i need 64bit dos based assembler. (not GUI assembler)
9 years ago on Step 3
download link is removed form 4shared please update the link.
10 years ago on Introduction
Cool. Do not have any 64 bit machines, so we downloaded the 32 bit version to play with.
