Introduction: How to Sew an Original Jean Hem
Many people prefer to have an Original Hem treatment done to their designer jeans. Even if you can duplicate the thread color and distress marks to a certain extent, some hem decorations are far beyond the typical DIY's tools and materials, and are just downright too much work for even the professional to duplicate. I'll show you the methods to attain professional results, saving yourself $25-$40. Let's go find some jeans!
Step 1: Prepare the Hem
- Get a pair of denims
- Press out hem if it is wonky-looking
- These need to be 3" shorter, so I mark 3" from bottom.
- Fold up 2" for these, or so that old hem bottom is 5/8" above 3"(or whatever yours is) chalk line. This is because after stitching right sides together, you will flip down old hem, which is ~ 5/8".
- Press with iron at this fold along entire hem.
Step 2: The Trick Is in the Foot and the Method
A lot of how-to's for this type of hem don't use the correct foot or method, so they don't get close enough to the original hem stitching.
- Use a zipper foot. This type from Husqvarna is the best one for this treatment. Adjust needle to the far left.
- Remove sewing platform to give yourself more control.
- Pull back hem fold to open up the space.
- Wedge sewing foot as far into that as you can. This should cause the fold to stand up at 90 degrees.
- Start sewing, stretching the hem as you sew, slightly pulling right, into the foot. The goal here is to keep that fold standing up, and not droop down where the needle could catch it.
- This is how it should look while you are sewing.
- Make sure that the side seams are lined up as you approach them. If you have a hard time manipulaling the bumps here, just go slowly, turning the handwheel. I prefer to go full speed, because I know that this machine, with the proper jean needle, will have no problem going through everything. Momentum is your friend!
Step 3: Cut Edge and Lockstitch
- Pink edges or
- Serge them
- Press inside
- Press outside, using a ham to get a nice, hard fold, just shy against that original stitching. Not over or too close, you don't want it covered any amount.
- Stitch that fold very close to the edge, manipulating it's placement if needed while you are sewing.
- All done! Press with strong downward force, on a high heat/steam setting. These will always look nice, even after washings. No flip out, no maintenance ironing.
Step 4: The Tutorial in Video Format
On a Budget Contest
29 Comments
7 years ago on Introduction
I did these on used jeans for someone and when they washed them the hems fell apart. I am still trying to figure out what went wrong.
Reply 6 years ago
No final da costura onde está o começo deve fazer retrocesso para fixar a costura do início com o fim.
Oh, no! The seams should be very strong and that should never happen. Did you use jeans thread/size 16 needle?
6 years ago
Sometimes the bottoms are flared or tapered, would this still work or just for very straight legged pants?
Reply 6 years ago
Right, if you have to shorten by more than a few inches, the change in circumference could make doing this quite tedious(having to reconcile the difference), not to mention the jeans color, if a gradient, might also be slightly different.
6 years ago
I wear a 42/29 and can usually find 42/30. I usually shred the back of the cuff within 6 months. I've tried duct tape, but it comes out in the wash. I've tried the "quick stitch" place and press glue strips - same problems.
I may have to invest in a zipper foot and a few heavy duty needles for my machine. Thanks for the tips!
6 years ago
That's way too much work. Use a walking foot machine with heavy brownish gold thread . Cut the jeans about an inch and a quarter than intended length. Roll it under and stitch it with a matching stich length.
8 years ago
Hi, excellent tutorial, I've been using this method myself for years now. I didn't use the zipper to get in closer to the hem but still get excellent results, (never had a anyone getting down on their knees to look closer) but then I have only ever bought cheap jeans. Next pair I do will definitely try the zipper foot now though.
Thanks for the instructible, very easy to follow.
Cool! Yes, you want the least amount of material to duplicate the original, or you will get some unnatural rigidity and eventually some unintended wear lines.
hi!
LOVE this!
do you cut off the extra or just leave it folded up?
Thanks!
: D
Hi back!
If you are in "view all steps", look up about 20" and you'll see two options; pink or serge.
Great tip!
8 years ago on Step 4
Nice tutorial. $25+ to hem a pair of jeans and then the person making the hem can't do it right?WoW! I'm not sure where you are located,but here,I pay at most $6 per pair.The stitching is always the same as the manufactures.So yeah,this could save someone some serious money paying those $25+ prices,especially if many pairs need to be altered.At those prices it makes buying sewing machine worth it.2 thumbs up.
Reply 8 years ago on Step 4
Thanks! Yeah, I charge $25, but others around here who do an unacceptable job, charge $40. Most people around here(Northeast US, or any major city) charge $10-18 for a reg hem. That takes about 10 minutes with the measuring/pressing/cutting/sewing.
Thanks for this! I do some sloppy prototyping sewing and this weekend I realized I need to polish my skills. This is very helpful thanks.
Thanks, and You're welcome!
I got a sewing machine with a zipper foot for Christmas, so I've been itching to try it out. This sounds like a great first project. Love how clear your instructions and pictures are, thanks!
Nice!! You're very welcome! Please don't hesitate to message if you have any questions. ~ Cynthia
I recently picked up a thrifted pair of jeans with this treatment. Pretty slick!
: D
