How to Solve the Problem of More Than 10 Meters Single Color Lighting Failure?
Intro: How to Solve the Problem of More Than 10 Meters Single Color Lighting Failure?
Solve the problem of more than 10 meters Single Color lighting failure
STEP 1: No Lighting Decay Phenomenon
There is no lighting decay phenomenon when you connect 5 meter led strip light:
STEP 2: Lighting Decay Phenomenon
There are obviously lighting decay phenomenon when you connect(series connection) 10 meters led strip light:
STEP 3: Solve the Lighting Decay
The way to solve the lighting decay: you need to use a LED Strip Amplifier when you connnect another 5 meters led strip(If you want to connect 10 meters, you can use 1pcs LED Strip Amplifier;connect 15 meters,use 2pcs LED Strip Amplifiers), like the following picture shows:
STEP 4: The Installation of Power Supply and Led Controller:
Use a DC cable to connect the V+ V- of the power supply AC input, connect the power cord(US/UK/AU/EU) with the DC cable. And use another cable line to connect the DC output of the power supply and the DC input of led controller. And then you can use a single color LED connector to connect the DC output of led controller and single color led strip lights you have.
STEP 5: The Installation of Led Strip Amplifiers and Led Strip Lights:
Connect the input of the led Strip Amplifier and led strip light, at the same time you need to use another power supply to connect the led strip amplifie. If you want to connect more led strip lights, you can choose LED Splitter to connect.
