Introduction: How to Teach Osmosis
I originally used this instructable as a demonstration to explain osmosis to my classes.
Over the years many of my pupils told me they'd tried it for themselves at home (got their interests, half my job was done). I've started using this method as a practical with some of my classes with great results and plenty of opportunities for pupils to visualise cells and osmosis also for extension work to challenge the more able (you know the one that has finished, while you're still explaining what to do to others).
Over all it does take 5 days but you can take about 2 days off by putting the eggs in vinegar yourself but it does loose some of its WOW.
I took these photos before I decided to make this instructable so sorry if photo doesn't quite fit the step.
Step 1: Equipment
2 x eggs
about 500ml of vinegar (I normally use the distilled white vinegar, but this bottle was only 14p)
2 x 250ml Beakers
bag of sugar
2 x 500ml beakers
Post it notes or Sticky labels
1 x balance (the more accurate the better)
Step 2: Dissolve the Egg Shells
Place each of the eggs into a 250ml beaker and cover with vinegar. Place them in a spot where they wont be tampered with, (then put them somewhere even safer with a note on them, saying "do not touch"). Leave for 2-3 days (over weekend is best, you can set them up on a Friday lesson and revisit Monday/Tuesdayish.
Step 3: The Fun Part
The eggs now have no shells but are intact. Retrieve them using a spoon, or gently emptying the beakers into a sink.
This is normally the only problem part as some pupils are put off by the smell of vinegar.
I am always paranoid of the bursting them, but this hasn't happened yet, and the ones that get dropped are easily cleaned up with some paper towels.
Step 4: Measuring the Mass
Place each egg on a balance and measure its mass as accurately as the equipment allows.
write each mass and conditions that each egg will be kept in on a separate label.
Step 5: Osmosis
Put one of the eggs in a 500ml beaker and fill with water (don't forget the label).
Fill the other 500ml beaker with water and make a saturated sugar solution. (put so much sugar in so it doesn't dissolve any more).
Put the remaining egg in the sugar solution and label.
Place the beakers somewhere safe and wait 2 to 3 days.
Step 6: The Final Effect
Basically remove the eggs, weigh them again, and calculate the change in mass.
I have had some amazingly visual effects at this point, the egg in the sugar solution can shrivel up to a third it's size and the one in water can expand to look like a fully loaded and primed to go water balloon (the kids notice this resemblance, you've been warned).
Make sure everyone washes their hands at the end of this practical.
Step 7: The Science Bit
The water is moving through the eggshell (semi-permeable membrane also called a selectively permeable membrane) from an area of high concentration to an area of low concentration.
Step 8: Extention Work
Tell the pupils to:
a) describe what is happening to each egg.
b) calculate the percentage mass change
c) draw a graph of class average results.
The Teacher Contest
12 Comments
4 years ago
I used this to help pupils see the effect of Osmosis, before allowing pupils to carry out experiments using potato and salt water solution, as it is easy for pupils to imagine the egg as one animal cell. It is very impressive when the egg swells up like a water balloon or shrivels up. The egg bursts very easily, so handel with care.
Question 4 years ago
how much of the masses do you need to make it work?
Reply 4 years ago
Hi, the masses are of the eggs before and after they were put in the soloution. One egg was put in water and the other in a saturated sugar soloution (as much sugar as I could dissolve in the water). Hope this Helps.
4 years ago
it looks good and the outcome was good, great job!
7 years ago
good info.Thanks for clear explaination.Here is an interesting Osmosis app i found it is a quick and easy to experiment with various solutions on different concentrations in the experiment to determine the osmosis values . here is the link https://play.google.com/store/apps/details?id=air.com.ajaxmedia.osmosis
11 years ago on Step 8
Excellent!
11 years ago on Introduction
Nice job. I teach organic chemistry, but I'll forward this to my general chemistry colleagues.
Are you entering this project in the teacher contest?
Reply 11 years ago on Introduction
hello. yes, I am hoping to enter the contest . Would appreciate the votes ;)
Thanks. Home school teachers appreciate this kind of project.
Wonderful Instructable, bravo. When I did this, watching the eggs grow and shrink was very exiting. Try putting the eggs in Karo syrup or corn syrup. The effects are very dramatic ;-). Hooray for science!
11 years ago on Step 6
Yay, science! I'm a working physicist, and p-chem like this has always been my downfall. Somehow, the fact that osmotic pressure can work even in the absence of a physical pressure difference still seems like magic :-)
