Introduction: How to Trace Images in Photoshop Elements 6
In this instructable I will be showing you how to trace any image and make it look like you sketched it. This is fairly simple and if you want you can make it more detailed.
To do this you will need:
1. Photoshop Elements 6 ( Or any form of photoshop)
2. A computer
3.(Optional) a pen tablet to help you trace.
2. A computer
Step 1: First, Find Yourself a Nice Image.
go on the internet and find an image to trace, or you can scan a picture that you have.
i used Iron Man because the lines on the picture are much more simple than a real picture, but any picture will work.
Step 2: Next, Open Up Photoshop and Set Up the "tracing Paper"
Now open up Photoshop, and upload that picture. Then make another layer, and use the fill tool to make it white. then set the opacity to any number between 15 and 45. I used 255 so that I could clearly see the lines and the image, but if your image is darker you may want to lower the opacity.
Step 3: Start to Make Lines
start to make lines wherever there are basic lines in the image, and if you want to put more detail in, create lines where you see small details, like the shine on Iron Man's chin.
Step 4: Finish Up the Tracing
Keep tracing, and when you are done turn the opacity up to 100% so that you can see your drawing.
Step 5: Add Color
put the opacity down so that you can see the colors on the original image, and put it back up to fill the colors in. I tried to match the colors as much as I could, but I did not do a very great job.
Step 6: All Done!
Finish up the coloring, save, print, and brag about your amazing artistic abilities.
