Introduction: How to Turn a Millennium Falcon Into a PC!
***I guess I should've mentioned this to begin with that I didn't use a Millennium Falcon that was is good shape. I had to give it a bath in bleach to remove a bunch of stains and the smells that went along with them. I had to reinforce the rear feet because they could no longer support it's own weight let alone the weight of a computer inside it. There were also parts missing that I had to find to make it whole again.***
Step 1: Materials Needed
Han Solo and Chewbacca Action Figures (I chose the 1978 Kenner Large Head Han Solo so I could use him as the power switch and used the 1977 Kenner Chewbacca, I also found these guys on eBay)
Mini ITX motherboard (I used Foxconn H67S LGA 1155)
CPU (I used Intel Core i3-2100T I chose this one because it's low profile and doesn't stick up as high as the normal version.)
PSU (I used picoPSU-160-XT and 192w AC-DC Power Adapter, 12v 16A) (This is the component that took the longest to find)
RAM (I used G.SKILL 8GB (2 x 4GB))
HDD (I used OCZ Vertex Series 30GB Internal Solid State Drive) ( I used the 30gb because I'm only using this for streaming movies and music, Everything I access is either from mapped network drives or on the Internet)
6 x 40mm Fans (I used two 40mm black fans and four 40mm blue LED fans)
6 Port Fan Hub (I used Sunbeam Multi Fan Power Port)
Plexiglass cut to size of Motherboard (You can get this at your local hardware store and usually if asked they will cut to size needed)
Motherboard Standoffs (However many your motherboard supports – Mine was four)
24 x Fan Screws (I used Black Fan Screws)
Miscellaneous cables (This all depends on what you want to put in to it but here’s a list of what I used)
1 x 3 Pin Fan Power Y Cable
1 x 4 PIN Molex Adapter TO 3 PIN Fan Adapter
2 x 3 ft. Panel-Mount USB 2.0 A Male to A Female Cable
1 x 3 feet HDMI Panel Mount Cable
1 x 18” Sata to Right Angle Sata (I already had one of these but you can get them pretty much anywhere)
1 x 2 Pin HDD LED and 1 x 2 Pin Power Switch (I already had both of these from an old PC case but here’s a link to a kit you can buy ATX Case Replacement Wire Kit)
1 x Molex 4 Pin on/off Power Switch 12V DC
CAT5 cable or Wi-Fi adapter (I used a cable because I wanted a fast connection for streaming)
Tools Needed:
Dremel Tool
Drill and bits
Phillips Head Screwdriver
Epoxy
Superglue
Hot Glue Gun and a glue stick
Sandpaper
Velcro strips
Cable strippers
RJ45 Crimpers
Punchdown Tool w/ 110 blade
RJ45 Keystone Jack (Almond color to match the Falcon)
RJ45 modular plug
Step 2: Disassembly
If it came with them remove the paper divider, sound maker, and center gunner’s seat.
Step 3: Clearing the Area for the Motherboard
Grab your Dremel tool and cut out the thin plastic divider and two studs. Sand it down as much as you like, this area will be covered up but I would just make sure the rough edges are gone.
Step 4: Cutting Out and Mounting the Fans
Step 5: Putting Together the PC
Step 6: Cutting Out and Mounting All Cables for Exterior Connections
Step 7: Installing the Power Switch
Step 8: Connecting Everything Up.
I started with the cable that came with the PSU. Connected the Sata end to the HDD. The Pata end I connected to the PATA power cable with 3 pin fan connector. Connected the black fans on the ends to the 3 pin Y cable and plugged the other end into the cable with the 3 pin fan connector. I then plugged the open PATA end into the power switch for the fans and the power switch into the 6 port fan hub and the fans into the hub. Next I placed the HDD in and the motherboard over the top of the cables and plugged in the cable on the PSU into it's adapter, and repositioned all the cables where they need to plug in. I started with the HDMI cable. It’s thicker than the others and not as flexible so I went with it first and worked around it. I placed the 6 port fan hub in next. I then plugged in the USB cables and they hold the 6 port hub in place. Next I plugged in the CAT5 cable and last I plugged in the 2 pin power button. The power button plugs in in different spots on all motherboards so you'll just have to check the documentation that came with your board.
